Re: smoking ballast
[Re: 2JcodeChargers]
#2749114
03/04/20 11:30 PM
03/04/20 11:30 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The blue wire feeds the resistor for the ignition . So any excessive draw would be from the ignition side. The regulator and alternator are fed on the same input side or supply side to the resistor. The charging system is not on the resistor side. The resistor will get hot and a new one may smoke until the coating wears off. Try a new condenser. I have seen many failures. Also make sure the distributor lead is not grounding out in the distributor attachment area or condenser lead. Also make sure the coil is for an external resistor.
Re: smoking ballast
[Re: RapidRobert]
#2749133
03/05/20 12:49 AM
03/05/20 12:49 AM
Posts: 1,757 Phila
PhillyRag
Phila
Sounds like an intermittent continuity issue on the primary side. Making-Breaking Contact. Worst after some time (i.e. heating). Condition on those wirings & connections? Old/New wiring harness? Higher rpm == higher amp load on ignition circuit. May run OK at idle, then crappy otherwise. If/When you have it idling OK, wiggle wiring & observe.
Re: smoking ballast
[Re: TJP]
#2749365
03/05/20 06:57 PM
03/05/20 06:57 PM
RapidRobert
post what it ends up being
