Distributor drive bushing question
#2749016
03/04/20 06:42 PM
03/04/20 06:42 PM
Posts: 4,179 California
mickm
California
I replaced my bronze drive gear and the bushing. There is about 50 miles on this, and you can see that the bushing is already scored. The underside of the driver gear is scored as well, I can feel it when I run my finger nail across it. When I installed the new gear, it was well lubed with oil, and I used assembly grease on the contact area between the gear and bushing.
Thing is, my old one was like this too, old bushing and gear. Not long after the engine was together I found it, and the wear seemed significant, so I installed a very thin washer between the two, and all was well from then on.
Should this be wearing like this? Seems that if I have two doing the same thing it is normal, but I wouldn't think this would happen.
Re: Distributor drive bushing question
[Re: mickm]
#2749081
03/04/20 10:04 PM
03/04/20 10:04 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
Roller cam or not? How much cam end play with new bushing and how much now?
[Re: mickm]
#2749134
03/05/20 12:50 AM
03/05/20 12:50 AM
RapidRobert
so I installed a very thin washer between the two, and all was well from then on. what about repeating that with a new bushing/same thickness washer?
[Re: RapidRobert]
#2749165
03/05/20 07:44 AM
03/05/20 07:44 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Replace the bushing, have the drive gear faced (remove material to match the thickness of the washer .032”.) Use a precision hardened washer between the two parts. Two similar metals should not be in contact with each other. Mcmaster Carr #5909K44 $1.10
[Re: TRENDZ]
#2749187
03/05/20 09:39 AM
03/05/20 09:39 AM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Replace the bushing, have the drive gear faced (remove material to match the thickness of the washer .032”.) Use a precision hardened washer between the two parts. Two similar metals should not be in contact with each other. Mcmaster Carr #5909K44 $1.10 BINGO !! Bronze gear against bronze bushing = severe wear. Use a washer from a torrington bearing - any bearing supply house will have them.
[Re: Stanton]
#2749246
03/05/20 12:51 PM
03/05/20 12:51 PM
Posts: 11,606 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Hard thrust washer(s). Check, adjust and correct the end play with the washer stack while doing it.
[Re: Stanton]
#2749427
03/05/20 09:31 PM
03/05/20 09:31 PM
mickm
California
Replace the bushing, have the drive gear faced (remove material to match the thickness of the washer .032”.) Use a precision hardened washer between the two parts. Two similar metals should not be in contact with each other. Mcmaster Carr #5909K44 $1.10 BINGO !! Bronze gear against bronze bushing = severe wear. Use a washer from a torrington bearing - any bearing supply house will have them. Yup, that makes sense. Will do that.
