Recommendation For Carter AVS Rebuild Kit? #2748874
03/04/20 10:28 AM
03/04/20 10:28 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have a recommendation on a brand rebuild kit for a Carter AVS (4738 - 440 w/ 4-Barrel)?
Re: Recommendation For Carter AVS Rebuild Kit? [Re: vinnyd76] #2748901
03/04/20 11:56 AM
03/04/20 11:56 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I use Mike’s carburetor. 888-689-9758. I have had no problems with his kit. It’s good quality.
Re: Recommendation For Carter AVS Rebuild Kit? [Re: fastmark] #2748983
03/04/20 04:17 PM
03/04/20 04:17 PM
E
earlymopar Offline
earlymopar  Offline
E
I 2nd that recommendation.
- EM
Re: Recommendation For Carter AVS Rebuild Kit? [Re: earlymopar] #2749019
03/04/20 06:55 PM
03/04/20 06:55 PM
New York
rarefish Offline
rarefish  Offline
New York
I have used the Hygrade kits from Rockauto with no problem. I'm not sure how they compare
to other kits out there.
Re: Recommendation For Carter AVS Rebuild Kit? [Re: vinnyd76] #2749040
03/04/20 08:20 PM
03/04/20 08:20 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Funny you should ask:
Just bought this:
https://www.amazon.com/Standard-Mot...;psc=1&ref=ppx_pop_tab_ap_asin_title
I've used the Hygrade kits since the 80s.
Never any problem. These are the kits that have stood the test of time.
This is probably the 20th kit I've done over the years. Amazon has the best price on this and the fastest delivery if you can't find it locally. NAPA used to carry these back in the day....but find a NAPA these days...lol.
There's lots of tips for rebuilding but my favorite is to spray the cardboard gasket for the lid to main body with cooking oil. It won't stick if you have to take the top off and the cooking oil is harmless. I generally hit all the gaskets with cooking spray. But the main body gasket is the most important.
Enjoy!
CC.
Re: Recommendation For Carter AVS Rebuild Kit? [Re: rarefish] #2749129
03/05/20 12:32 AM
03/05/20 12:32 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
iagree Have used them since the 60's,never a problem!
Re: Recommendation For Carter AVS Rebuild Kit? [Re: 62maxwgn] #2749136
03/05/20 12:53 AM
03/05/20 12:53 AM
iirc John from "the carburetor shop" recommended Hygrade also
Re: Recommendation For Carter AVS Rebuild Kit? [Re: RapidRobert] #2749161
03/05/20 07:23 AM
03/05/20 07:23 AM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
Ahhh the old days of walking onto the store and buying a Jiffy Hygrade carb kit. Counterperson would say "Dont forget a new float and possibly an electric choke conversion kit." (NAPA all thru the 80s stocked them all)
Keep old mopars alive.
