Re: holly carb question
[Re: cupcake]
#274889
04/02/09 11:01 AM
04/02/09 11:01 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
stock are 70/71 pri with PV and 80/81 sec with no PV
WAXER
[Re: cupcake]
#274890
04/02/09 11:34 AM
04/02/09 11:34 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
750 DP holly has 71 jets in front what should be in the sec
It depends on which dash # the carb is and if it is still stock with no modifications. Holley has made a bunch of changes to all of its DP series carbs over the years,some have internal modifications and some where external like on the linkage changes. Post which list # yours is including the dash # ,IE 4779,(first generation with no dash #) 4779-1,-2 thru -9, then we can look up the stock jetting and you can go from there.
