65 to 68 'B' block variations? #2748807
03/04/20 01:21 AM
03/04/20 01:21 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Okay, so I checked with a local machine shop (guy does mostly heavy equipment but does all things well), about a basic rebuild on my 65 383. He calls his parts supplier who proceeds to tell him that they only stock engine kits for 68 and up 383's. I can't recall any significant differences between the pre/post 68 383's especially on the short block side, am I forgetting something here? Why wouldn't a post 68 overhaul kit work on a pre 68??? (Not talking the 59 RB 383's here.)
Re: 65 to 68 'B' block variations? [Re: 1E2C] #2748808
03/04/20 01:33 AM
03/04/20 01:33 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Several things I can think of off the top of my head is the 67 and older had engine had a different lifter and pushrod than the more common later style big block setup, the 68 and newer had the same size pushrod ends which i believe both were 5/16 where the 67 and older had two different size pushrod ends one being 1/4 and the other is 5/16. The older motors can be easily updated to the newer set up if needed.
Also 67 and older motors had closed combustion chamber heads where as the 68 and newer used an open combustion chamber head, I believe the piston compression heights are different.
Re: 65 to 68 'B' block variations? [Re: chargerbr549] #2748809
03/04/20 01:40 AM
03/04/20 01:40 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Okay, I had forgotten the lifter differences with the pre 68 having the smaller bottom ends. The 516 closed chamber heads I didn't think would have a major impact on the bottom end. I mean the lifters/cam are typically serviced separately, aren't they?
Re: 65 to 68 'B' block variations? [Re: 1E2C] #2748810
03/04/20 01:47 AM
03/04/20 01:47 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Lifter and cam diffs ?????
The only thing I’m aware of is the CD of the early and later pistons.
If you use the 68 + pistons ... you will get a much better compression ratio ... which should still be ok with regular gas of today
Re: 65 to 68 'B' block variations? [Re: dOoC] #2748835
03/04/20 08:58 AM
03/04/20 08:58 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You’ll just need to be careful about piston choices. I’ve been going through the same thing selecting pistons. The blocks are the same. It’s the pistons and heads that were different. Don’t think you can even buy the early lifters. Just get later pushrods. Don’t get the cheap ones with the balls welded on the end. My customer had one break off and cause catastrophe failure. My build is using later open chambered heads and seal power forged pistons with the higher compression height. They make cast pistons with a lower compression height. I don’t use the KB hyperutectic. I’m out of town visiting with the kids but I can dig out my measurements by tomorrow morning and post them. It should help you out.
See my post below. I had some time to kill and had my infor with me.
Re: 65 to 68 'B' block variations? [Re: fastmark] #2748857
03/04/20 09:46 AM
03/04/20 09:46 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
That would be handy info to have.
Re: 65 to 68 'B' block variations? [Re: 1E2C] #2748882
03/04/20 10:46 AM
03/04/20 10:46 AM
montana
BANDIT Offline
BANDIT  Offline
montana
On my buddies ‘66 383 4-bbl motor, we are just using the later low compression 2 bbl pistons. It’s a stock rebuild, so they are cast, compression ht was very close if I remember correctly. Stuff will be back from machine shop Friday nite, I can compare them again. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 65 to 68 'B' block variations? [Re: BANDIT] #2748898
03/04/20 11:51 AM
03/04/20 11:51 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
What Heads are you using? The 516 I have at the shop had 79cc for chamber volume. I’m pretty sure they were factory untouched.
Re: 65 to 68 'B' block variations? [Re: fastmark] #2748907
03/04/20 12:25 PM
03/04/20 12:25 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My suggestion is for you to use the tutorial on the JE piston website and figure your compression ratio with long math and not an online calculator. You can more easily see what changes make the difference in CR.
My KB 162 has a deck height of .031 below the deck with a stock block, unmilled. Yours could be a little different. They have a published compression height of 1.908. They have big(8cc) valve reliefs.
The L 2315F has a compression height of 1.920 and no valve reliefs.
Another cast stock type Sealed power piston has a lower CH. It’s 1.848. It’s part no 366AP.
I’m using 87 cc 452 heads.
Stock shim steel head gaskets were .023 and the felpro blue is .039.
Like I mention earlier, 516 closed chamber heads should be around 80 cc.
Good luck.
Re: 65 to 68 'B' block variations? [Re: dOoC] #2748949
03/04/20 02:35 PM
03/04/20 02:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, pre-'68 pushrod has a smaller ball lower tip and in '68 cam lobe profile changed.
Re: 65 to 68 'B' block variations? [Re: John_Kunkel] #2748995
03/04/20 05:01 PM
03/04/20 05:01 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Now THAT slipped my mind but I kind of read that initial post as the later model cam and lifters not fitting into a 65 block ...
Re: 65 to 68 'B' block variations? [Re: dOoC] #2749009
03/04/20 06:11 PM
03/04/20 06:11 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
So I stated it poorly, John showed exactly what I meant to say. :-P
Re: 65 to 68 'B' block variations? [Re: fastmark] #2749010
03/04/20 06:15 PM
03/04/20 06:15 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Good luck.
No easy answers, huh?? Really it just means I have to get it all torn down so I can start with some known values - I did rebuild it once already, but I looked up the paperwork today and it's not much help as most of the part numbers have changed since 1983 and my memory isn't that precise.
Thanks, I think I'll give up on the shortcuts................
Re: 65 to 68 'B' block variations? [Re: fastmark] #2749195
03/05/20 10:21 AM
03/05/20 10:21 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Yes, we are using stock 516 head, I had bought the pistons from the machinist. We just compared CH rather crudely by shoving a pin thru both pistons. Now I’m curious how accurate that was. Guess I’ll know tomorrow nite when he brings stuff over. Jim
4600 DA
