Hydraulic roller for 505"
#2747113
02/27/20 03:07 PM
02/27/20 03:07 PM
Posts: 215 portland, ct
Since1822
portland, ct
Looking for opinions on the roller cam that came in this 505" shortblock that I got with car. Pump gas motor with cnc stealth heads- cam is an older hughes grind: 236/242 duration .560/.570 lift 110 lsa installed at 107. Going in a street trim satellite, 3.91gears auto with 3000ish converter. I'm trying to decide whether to throw a solid in it or buy a set of roller lifters and run it. I am guessing it would run pretty good in a street car. RPM intake with nice 950ish carb
Re: Hydraulic roller for 505"
[Re: viperblue72]
#2747140
02/27/20 05:09 PM
02/27/20 05:09 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
It ought to drive real nice on the street and be a torque monster, but it's a lot smaller than what I'd have wanted for a 500" motor. I'd pick something like that for a stock stroke street motor.
[Re: an8sec70cuda]
#2747148
02/27/20 05:33 PM
02/27/20 05:33 PM
Posts: 4,678 Wichita
GY3
Wichita
I run a Howards hydraulic roller that is very similar in lift and duration. It makes for a great street car and is pretty quick to boot!
[Re: GY3]
#2747168
02/27/20 06:46 PM
02/27/20 06:46 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would run that cam and focus left over funds on optimizing traction. Since a street car seldom sees lots of rpm, torque becomes a great thing to have an excess of.
[Re: AndyF]
#2747196
02/27/20 08:37 PM
02/27/20 08:37 PM
Since1822
portland, ct
That should be a really nice street cam. The hyd roller that I have in my Coronet is roughly the same size but on 112 lobe centers for even less overlap. For your application I'd say that cam is a pretty good choice. This is great news. Andy, did you use the Comp lifters with the Coronet motor? If not, what do you suggest for this application? I called Hughes and they suggested using the Howards they sell. Thanks to all for the advice.
