Re: Seeking: Top notch engine builder in SoCal
[Re: JF_Moparts]
#2746641
02/26/20 10:50 AM
02/26/20 10:50 AM
Posts: 3,516 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
While I have not used them, I have been very impressed with QMP:
QMP Racing Engines At Quarter Mile Performance, all services we offer are done under one roof at our shop in Chatsworth, Southern California. Everything is done inhouse, no service is ever outsourced. We can do anything from basic surfacing to machining a custom piston from a blank forging.
We do everything from building your engine to our complete, turn key QMP Racing Engines. Whether you're racing in Heads Up Fastest Street Car (Nitrous/Turbo/Blower/NA), NHRA/IHRA Comp & Super Stock, Marine, Drag Boat, Street & Strip, we have the proven combinations to get you to the winners circle. All complete QMP Racing Engines are dyno'd with true HP numbers. Tell us how fast you want to go, and we will make it happen. Check out the finished vehicles page. Complete engines are now for sale.
[Re: JF_Moparts]
#2747080
02/27/20 01:56 PM
02/27/20 01:56 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Not sure if you are going to perform the R&R yourself or looking to have someone help you with that..... Anyway, Check with Bill... He is local to you and a Mopar guy. He could give you a hint of who might be near you that could do the mopar deed. I like Mike and the crew over at JMS>>>>>> https://jmsracingengines.com/But you should not find it to hard to find someone to fix up that Mopar Motor with a little extra power for you. Best of luck: Cheers
Bob(Cowboy)Hogan Monrovia So-Cal
