'77 W-200 fuse panel/circuit breaker #2746449
02/25/20 02:52 PM
02/25/20 02:52 PM
Norway
General 68 Offline OP
Norway
Hi! I am re-wiring a '77 W-200 truck and just ran into a small problem. A circuit breaker with a small 3'-ish wire harness attached to it is located at the fuse panel. I can't find out what the other ends in this harness should be attached to. Can't find the breaker or the harness in the wiring diagram either. Pictures show the breaker, its terminals and harness. Any ideas? Thanks
Re: '77 W-200 fuse panel/circuit breaker [Re: General 68] #2746455
02/25/20 03:11 PM
02/25/20 03:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I can not tell you for sure but I do believe that is for a 2 speed rear end. I know my 75 D-800 had it. That bare fuse block was used on all D & W series trucks. So maybe someone swapped it out before you got it. The one other item that comes to mind on trucks with the camper special package. It is possible that it was used for a camper harness. For now if you are not concerned about being factory original just make a diagram and remove it for now.
Re: '77 W-200 fuse panel/circuit breaker [Re: NITROUSN] #2746465
02/25/20 04:04 PM
02/25/20 04:04 PM
Norway
Norway
You are the man, Nitrousn👍😀 Exactly what I needed to know. I think I'll just tie it up under the dash😀
Re: '77 W-200 fuse panel/circuit breaker [Re: General 68] #2746517
02/25/20 07:45 PM
02/25/20 07:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Hopefully that will fix you up. As I looked that harness over and the wire colors used it could of been also a harness that used a relay off that black plug. Which would of been used by the body installer on cab and chassis models for body lighting. With 10 to 16 body [marker] lights they would of needed another power source for all that draw.
Re: '77 W-200 fuse panel/circuit breaker [Re: NITROUSN] #2746543
02/25/20 09:28 PM
02/25/20 09:28 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Possibly for auxiliary snow plow lights?
Re: '77 W-200 fuse panel/circuit breaker [Re: sportfury70] #2746548
02/25/20 09:42 PM
02/25/20 09:42 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No it was not used for plow lights that I know for sure. Plow lights were a simple switch with the hi-low inputting the push pull switch. Its either on plow or truck when you turn the main headlamp switch on.
