A engine hydraulic roller ?
#2746377
02/25/20 12:02 PM
02/25/20 12:02 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Have a 360/408 in the shop. OE block, 587 heads. Comp Cams cam and hyd roller lifters. Problem: push rods hit the push rod "tube" on the valve side of the head. Put in a solid lifter/pushrod and it is close but OK. So, the height of the hyd roller lifter seems to be at fault. Puts the pushrod at such an angle to hit. Has cast rockers. Borrowed a HS rocker for long valve install hoping to see a cure but no joy. Has anyone else had this happen?
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: A engine hydraulic roller ?
[Re: sixpackbee]
#2746381
02/25/20 12:11 PM
02/25/20 12:11 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
As I've just completed my new stroker (410), I debated flat vs roller. and the shop told me that with roller lifters being taller, then the pushrod holes in the heads would need to be opened up... and the pushrods would be shorter and at a more severe angle.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: sixpackbee]
#2746385
02/25/20 12:26 PM
02/25/20 12:26 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
This is why the factory HR motors have heads with much bigger pushrod holes.
[Re: fast68plymouth]
#2746394
02/25/20 12:42 PM
02/25/20 12:42 PM
sixpackbee
Western New York
When we raced Super Stock back in the day we used to have to mill the tubes to the intake side for clearance. The high lift would move the pushrods to that side. Never seen this though. I guess I have to take the heads back off and do some Bridgeport work.
