Re: Six Pack Negative Cable Serrated Washer
[Re: moparjohn]
#2746145
02/24/20 04:21 PM
02/24/20 04:21 PM
Posts: 673 Kennewick, Wa.
71vert340
Kennewick, Wa.
Is it a standard external star washer in a common size? Or is it a captured star washer that is part of the bolt head? Terry
[Re: gtx6970]
#2746765
02/26/20 04:17 PM
02/26/20 04:17 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
According to Frank Badalson, there is no washer here. This is from one of his tech articles I saved. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: sixbbl 69]
#2747940
03/01/20 07:27 AM
03/01/20 07:27 AM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
I agree. Look at the lack of paint on the cable end. It appears it was under the return bracket at one time. Makes sense that the factory would make the connection as to not be able to corrupt the ability for grounding with paint. But back to the original topic and picture, it may just be an optical illusion that there is a washer there. That is probably the serrations on the brackets that appear to be a washer.
[Re: RealWing]
#2751309
03/12/20 03:26 PM
03/12/20 03:26 PM
Posts: 57 Thomaston, CT
Frankie P
Thomaston, CT
Funny my 4 Bbl return spring bracket has the imprint from a star washer. I just didn't know if the cable was under the or on top with washer under the bolt head.
70 Charger R/T 440 4spd Dana
[Re: Alaskan_TA]
#2751323
03/12/20 03:50 PM
03/12/20 03:50 PM
Frankie P
Thomaston, CT
Thank you for the info. I'm I will not have to take a manifold bolt out of a freshly painted engine.
Frank
[Re: 70sixpkrt]
#2777499
05/23/20 09:12 PM
05/23/20 09:12 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
What is the consensus on the negative battery cable about over or under the bracket on a A12? Under the bracket same as the others.
