Hotter plug need # #2746055
02/24/20 11:59 AM
02/24/20 11:59 AM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Need a spark plug 1 step hotter than a NGK r5671-7 ? Ngk doesn't make a -6.
Need not be NGK for a street machine 440
Re: Hotter plug need # [Re: dafixr] #2746083
02/24/20 01:43 PM
02/24/20 01:43 PM
Is that a stock type iron head with a OEM type spark plug or a 3/4 inch SB type plug with the 5/8 inch socket size?
If stock try a Champion RJ10YC or a RJ12YC or a Autolite #84 or 85.
If it is the smaller 5/8 socket size with the 3/4 inch reach try the Autolite # 23 or 24 up
IHTHs
Re: Hotter plug need # [Re: Cab_Burge] #2746090
02/24/20 02:14 PM
02/24/20 02:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
NGK R5671-7 crosses to an Autolite 4054. Autolite does a 4055 and 4056 - 1 and 2 steps hotter. Standard non-resistor, 3/4 reach, 13/16 hex. 4056 is equivalent heat to the old 64.
Re: Hotter plug need # [Re: CMcAllister] #2746120
02/24/20 03:11 PM
02/24/20 03:11 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Not to get off topic, but is the a site that a guy can go to that shows cross reference on multiple plug manufacturers? I looked the other day and had a real hard time crossing some. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Hotter plug need # [Re: BANDIT] #2746156
02/24/20 04:42 PM
02/24/20 04:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
what cylinder head? I use autolite 3926's in edelbrock heads.
Re: Hotter plug need # [Re: dafixr] #2746171
02/24/20 05:51 PM
02/24/20 05:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NGK does make a #6 plug..........Like asked, cyl. head makes all the difference but here's a number that looks like it should work for an aftermarket head....R5674-6 or 4449 stocking number..
Re: Hotter plug need # [Re: Thumperdart] #2746676
02/26/20 12:40 PM
02/26/20 12:40 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Thanks for the info for alum edelbrock heads.
Re: Hotter plug need # [Re: dafixr] #2746719
02/26/20 02:11 PM
02/26/20 02:11 PM
I don't think you can use a 3/4 reach spark plug with the stock 13/16 plug socket size, I'm almost positive you need to us the smaller 5/8 socket size plugs scope Champion plug numbers RN9YC versus a RC9YC.
Autolite resistor plug # in 5/8 size I use are 3921 and up to 3924 in my race gas motors and the same 5/8 size in non resistor # in retracted gap are 3931 to 3935, 3931 is very cold.
Re: Hotter plug need # [Re: Cab_Burge] #2746726
02/26/20 02:29 PM
02/26/20 02:29 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
partial xref
Attached PDF document
sparkplug CrossRef.pdf (50 downloads)
Re: Hotter plug need # [Re: Thumperdart] #2748335
03/02/20 03:26 PM
03/02/20 03:26 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
That 4449 nil is not a 3/4” reach plug if that’s what’s needed. I bought a set, not sure I can use those being 7/16 reach
Re: Hotter plug need # [Re: dafixr] #2748341
03/02/20 03:53 PM
03/02/20 03:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
One step hotter than a “7”, but they have a projected tip:
BCP6ES
Or
BCPR6ES
Re: Hotter plug need # [Re: fast68plymouth] #2748838
03/04/20 09:06 AM
03/04/20 09:06 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thanks Dwayne. I believe the BCP6ES is a resistor plug. I like to run the non resistor type.
Re: Hotter plug need # [Re: mopar dave] #2748989
03/04/20 04:23 PM
03/04/20 04:23 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
for my aluminium head 440s I use a NGK BKR6E
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
