636 CI KB Hemi Block #2745348
02/22/20 12:23 AM
02/22/20 12:23 AM
Chicago Blackhawks
hemicar1971 Offline OP
Chicago Blackhawks
Any one put there order in on one of the new KB PN 51100 4500RT 636 Cubic Inch Block.
Keith Black Race Hemi Tall Deck
11.225 deck height
Raised Cam
2.00 lifter spacing
.905 lifter bores
48 degree lifter angle
Machined for 65 mm babbit / 60 mm roller cam bearings
Price is 7495.US only ten blocks being cast at present.
1971 HEMI E BODY REGISTRY
Re: 636 CI KB Hemi Block [Re: hemicar1971] #2745414
02/22/20 09:37 AM
02/22/20 09:37 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Its just an extra tall deck for more stroke. We need a 4.900" or 5" bore space block and parts to build LARGE engines. Just adding stroke is not the way to go.
Re: 636 CI KB Hemi Block [Re: fbs63] #2745435
02/22/20 11:18 AM
02/22/20 11:18 AM
Chicago Blackhawks
Chicago Blackhawks
I would think this block is for the person that is looking to buy a KB tall block now and is looking for a little more CI. It looks like it is built on what exists now. A 5 inch spread bore block, how many are going to be sold compared to what is offered as a hemi block on the market now. How long did it take for KB to even have blocks again and how many now are manufacturing a cast iron block for a Gen 2 hemi? If people go to an Alan Johnson block then it would be starting new with a complete parts list to buy. So if you were in the market now for an aluminum block and had all the parts from a past build to go on this block then one of the 10 blocks being cast might work for you.
Re: 636 CI KB Hemi Block [Re: hemicar1971] #2745529
02/22/20 04:33 PM
02/22/20 04:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am assuming that is with the 4.5 bore and a 4.80 bore space.....I have the 605 standard deck (4.5x4.75 stroke), and the pistons are pretty darn near as short as they can go in it...What rod length are they using in that combo?
As mentioned, I would also love to see a 4.90 bore space like the Noonan or AJ blocks where you no longer have the weird inside stubby bolts thru the deck into the valley......I have heard Noonan has/had a billet water block, but its not listed on their site. Would love an almost 670-700 cube NA Hemi in a water block...That would be bad ass..
Cubic inches rule!
Re: 636 CI KB Hemi Block [Re: hemicar1971] #2745603
02/22/20 09:05 PM
02/22/20 09:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Sorry, brain fade.
I thought B/RB were 45 degree tappet bank?
Boffin Emeritus
Re: 636 CI KB Hemi Block [Re: polyspheric] #2745663
02/23/20 12:55 AM
02/23/20 12:55 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
48 degree straightens out the lifters some
2011 Drag Pak Challenger
Re: 636 CI KB Hemi Block [Re: rickseeman] #2745710
02/23/20 11:03 AM
02/23/20 11:03 AM
Dragula Offline
Dragula  Offline
Re: 636 CI KB Hemi Block [Re: Dragula] #2745983
02/24/20 08:01 AM
02/24/20 08:01 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Std cam height is 45 degrees, raised cam is 48. The raised cam is what helps pushrod angle.
