R3 50mm can tunnel #2745117
02/21/20 04:51 AM
02/21/20 04:51 AM
Sydney, Australia
tuff440 Offline OP
tuff440  Offline OP
Sydney, Australia
Is an R3 block with a 50mm cam tunnel limited to roller cam bearings.
Re: R3 50mm can tunnel [Re: tuff440] #2745143
02/21/20 10:37 AM
02/21/20 10:37 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Just measure one of the cam bores...... that’ll tell you which cam bearings it takes.
Seems like there were a lot of different cam bearing options for those blocks.
Re: R3 50mm can tunnel [Re: tuff440] #2745174
02/21/20 11:48 AM
02/21/20 11:48 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My R-3 has babbits. they can be bored for roller. I think the preference is to bore them to a 60mm w rollers. There's better choice of cam cores at a reasonable price .
Re: R3 50mm can tunnel [Re: fast68plymouth] #2745293
02/21/20 07:18 PM
02/21/20 07:18 PM
Sydney, Australia
tuff440 Offline OP
tuff440  Offline OP
Sydney, Australia
The owner of the block says it’s a 50mm cam bore. I want to built a street engine so I don’t want roller cam bearings. Was there a 60mm Babbitt option.
Re: R3 50mm can tunnel [Re: tuff440] #2745297
02/21/20 08:01 PM
02/21/20 08:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
I seem to think there are 50mm babbit and roller options.
As well as 55 and 60, if theres enough meat in the cam tunnel.
There cam be issues with lifter oiling when the cam cores get bigger.
Re: R3 50mm can tunnel [Re: fast68plymouth] #2745877
02/23/20 09:04 PM
02/23/20 09:04 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
All 50mm cam tunnel R3 blocks were for roller bearings, from memory there is a durabond babbit bearing for a 55mm camshaft that fits the tunnel. There was an odd babbit size (largest cam journal on a factory camshaft, 1.998" I think), but I think they were the earlier R1 or R2 stuff
Alan Jones
