BAD 340 lifter bores.....HELP
#274511
04/01/09 10:15 PM
04/01/09 10:15 PM
Posts: 381 Denver CO
bennydodge
Denver CO
I'm posting this in the race forum in hopes that one of you guys encountered this problem and can maybe help me out.
Below are pics of the lifter bores of a '73 340. Notice the gap between the lifter oil band and the top of the lifter bore in the first pic. The cam is a Lunati solid with 582/582 of lift. The lifter is a Howard's solid EDM type. These pics are of a lifter at the top of the cam's lift in two bores side by side for comparison. The gap was MUCH larger with a roller setup.
What's the best fix? Bush lifter bores? Maybe a cam with slightly less lift?
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
Re: BAD 340 lifter bores.....HELP
[Re: bennydodge]
#274514
04/01/09 10:22 PM
04/01/09 10:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can have the cam re ground with a smaller base circle or a smaller lift. There are some other lifters that might work also but I'm not sure if they are hydraulic
[Re: aarcuda]
#274517
04/01/09 10:31 PM
04/01/09 10:31 PM
bennydodge
Denver CO
I'm worried about the groove(oil band on the lifter) being exposed. I know from experience the oil just gushes out and you lose your oil pressure.
[Re: bennydodge]
#274519
04/01/09 10:41 PM
04/01/09 10:41 PM
MR_P_BODY
There is a member on the board that sells a lifter that will/should work for you... his name here is something like ou812/Imm, he should see this post
[Re: bennydodge]
#274521
04/01/09 11:05 PM
04/01/09 11:05 PM
MR_P_BODY
There is a member on the board that sells a lifter that will/should work for you... his name here is something like omm812, he should see this post
Thanks MR P Body. I'll have to get in touch with him. Might be my best and cheapest option.
I'm pretty sure his name is Brian
[Re: MR_P_BODY]
#274522
04/02/09 12:38 AM
04/02/09 12:38 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Pretty sure?? How long have I been on here? I don't have any trick flat tappets. The old MP solid lifters were solid bodies. I know of nobody that makes a solid body FT lifter with an EDM oil hole. I can tell you, I never run edm hole'd ft lifters. I either groove the lifter bores, and nitride the cam, or use high end (ferrea) lifters. I prefer grooving the lifter bores and nitriding the cam and running correct oil. Brian
Brian Hafliger
[Re: Brian Hafliger]
#274525
04/02/09 09:19 AM
04/02/09 09:19 AM
MR_P_BODY
Sorry Brian I can barely remember my name
[Re: MR_P_BODY]
#274526
04/02/09 09:44 AM
04/02/09 09:44 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I've only seen a couple blocks mentioned that were hit that hard with facing. I've never had one personally. Must be a Friday block...lol
[Re: moper]
#274527
04/02/09 10:50 AM
04/02/09 10:50 AM
Posts: 15,491 the boonies
aarcuda
the boonies
Now that I look at pics of my own block, all i have to say is... wow.
[Re: MR_P_BODY]
#274529
04/02/09 11:19 AM
04/02/09 11:19 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
LOL....I hear that!! I was just messin' with ya Mike, er mark, er??? LOL! Brian
