W200 horn ring - missing parts #2744653
02/19/20 04:06 PM
02/19/20 04:06 PM
Norway
General 68 Offline OP
Norway
Hi
My '77 W200 truck is missing some parts in the horn ring. The big parts are there but someone has put screws where the isolators between the contact parts behind the push/horn pad are supposed to be. And ofcource cut the ground wire😂
I could needa pic and a description of how it is supposed to be. Shouldn't there be some rubber and maybe springs in there?
Re: W200 horn ring - missing parts [Re: General 68] #2744665
02/19/20 05:10 PM
02/19/20 05:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Tilt or regular column?
Re: W200 horn ring - missing parts [Re: NITROUSN] #2744822
02/20/20 01:27 AM
02/20/20 01:27 AM
Norway
Norway
Regular column. Steering wheel should be the same.
Re: W200 horn ring - missing parts [Re: General 68] #2744832
02/20/20 05:01 AM
02/20/20 05:01 AM
Guitar Jones Offline
How about a pic of what you have, different years may be the same.
Re: W200 horn ring - missing parts [Re: General 68] #2744882
02/20/20 11:02 AM
02/20/20 11:02 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Tilt is a completely different column. It was a Saginaw built column.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2744898
02/20/20 11:36 AM
02/20/20 11:36 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Parts manual. Page 1114 shows the upper column and page 1164 shows the wheel with horn switch. These are reference only as the wheel photo is of a tilt wheel. The individual parts are listed below the photo.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2744963
02/20/20 03:20 PM
02/20/20 03:20 PM
Norway
Norway
Thanks Nitrousn😀
I'll dig into it. Here is all the parts I have. Looks like I am missing the isolator spacer. Everything here now grounds.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2744977
02/20/20 03:57 PM
02/20/20 03:57 PM
Norway
Norway
Here is a pic after pullig the thing apart.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2745010
02/20/20 05:50 PM
02/20/20 05:50 PM
Norway
Norway
Found this pic at Allpar. The three black plastic pieces seems to be what is missing. What is inside them? Springs?
Re: W200 horn ring - missing parts [Re: General 68] #2745022
02/20/20 06:52 PM
02/20/20 06:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
All you need is the switch for your style wheels horn bad. I have a 1980 wheel in the shop. Three screws hold the switch to the wheel. Plug the wire on and snap the horn pad on. Someone made an abortion of yours.
Re: W200 horn ring - missing parts [Re: General 68] #2745042
02/20/20 08:27 PM
02/20/20 08:27 PM
Yes, mine has springs in it.
Re: W200 horn ring - missing parts [Re: Guitar Jones] #2745129
02/21/20 08:42 AM
02/21/20 08:42 AM
Norway
Norway
Thanks!
Seems like the isolators/fasteeners are missing then. I wonder how they look like other than from top view.
Someone has definetly done some work in there😂
Re: W200 horn ring - missing parts [Re: General 68] #2745144
02/21/20 10:39 AM
02/21/20 10:39 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Thanks!
You have nothing missing just a switch that is been taken apart and improperly put back together. Basically junk. I think someone found a switch and was trying to adapt the wheel center cap to fit it. The standard column only had the switch and 3 screws to bolt it directly to the wheel. The isolation was built into the switch. On a tilt column you had a wave type spring washer that went against the wheel then the switch, then a plastic 3 eared insulator, and then 3 shouldered screws. I will post a 1980 standard wheel with a horn switch for a round center cap. I would give it to you and your horn will work, but your center cap wont fit.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2745153
02/21/20 10:59 AM
02/21/20 10:59 AM
N
NITROUSN Offline
NITROUSN  Offline
N
First is tilt column. Second is non-tilt.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2745238
02/21/20 02:50 PM
02/21/20 02:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here are 2 more pictures of what you need. You can see the 3 screws that go through the switch into the horn pad adapter. You would take this switch part number 2771534 and attach your horn pad ring to it. Then you would screw it down through the 3 other holes to the steering wheel. The horn pad adapter is different than yours as seem by the photo. Just google the part number and get your part.
Re: W200 horn ring - missing parts [Re: NITROUSN] #2745240
02/21/20 02:55 PM
02/21/20 02:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
E-bay 19.99 right now. auction
Re: W200 horn ring - missing parts [Re: NITROUSN] #2745379
02/22/20 04:18 AM
02/22/20 04:18 AM
Norway
Norway
Thank you so much for your help, Nitrousn and all👍 Your pics and descriptions were perfect😀
Guess what: I stumbled over a steering wheel from a 68 Charger in the parts pile and it had the switch I was asking about intact👍 Correct parts number, but has some cracks in the plastic. It is now installed in the W200 steering wheel and works as it is supposed to!
Here are a couple of pics of mine. You guys rock!
Re: W200 horn ring - missing parts [Re: General 68] #2745439
02/22/20 11:23 AM
02/22/20 11:23 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Good to hear. Use what you have for now and who knows one day you may stumble on a nicer one. For what it is worth that fix may out last the truck.
