904 valve body in 727 Transmission #2743737
02/16/20 08:40 PM
02/16/20 08:40 PM
Pittsburgh, PA
roadrunnerh Offline OP
Pittsburgh, PA
Hello Folks,
Would it be possible to swap a 904 VB from a 1975 904 that was behind a my 225, INTO a 1968 727 that was behind a 440 Imperial?
This is in regards to my 1975 Scamp 225/904/7.25 to 383/727/8.75 swap.
I want to swap out the valve bodies - the '75 904 has three prong Neutral Safety Switch, my '68 727 has one prong.
Any problems with this? It seems the after market sells valve bodies as "904/727 valve body" same part number.
Thanks for any of your help - Much appreciated!
Harry
Harry
1968 Road Runner
1975 Scamp
Re: 904 valve body in 727 Transmission [Re: roadrunnerh] #2743742
02/16/20 08:52 PM
02/16/20 08:52 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
The park rod has to stay with the trans that it came in because they are a tad different between 904 to 727, not sure what you should do about the switch
Re: 904 valve body in 727 Transmission [Re: 500ciDuster] #2743824
02/17/20 01:26 AM
02/17/20 01:26 AM
Pittsburgh, PA
Pittsburgh, PA
Hey thanks for the reply.
Since the 727 is a '68 and my car and the 904 '75, if I swap the valve body, I'll be good to go with the correct neutral safety switch.
Harry
1968 Road Runner
1975 Scamp
Re: 904 valve body in 727 Transmission [Re: roadrunnerh] #2743917
02/17/20 12:32 PM
02/17/20 12:32 PM
moparx Offline
moparx  Offline
use the 727 park rod, and the 904 3 prong NSS with the 904 valvebody.
your 904 VB should also have the part throttle kick down module that the 68 VB may not have.
beer
Re: 904 valve body in 727 Transmission [Re: moparx] #2743940
02/17/20 01:19 PM
02/17/20 01:19 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Besides the Park rod, the rear center bolt hole prevents interchange. The hole in the VB transfer plate is elongated and the hole in the steel separator plate is located at one end of the slot on the 727 and the opposite end on the 904.
A rat-tail file can be used to elongate the hole in the steel plate.
Re: 904 valve body in 727 Transmission [Re: John_Kunkel] #2744005
02/17/20 06:59 PM
02/17/20 06:59 PM
Pittsburgh, PA
Pittsburgh, PA
Thanks guys, I truly appreciate the great information. This 727 will be going behind my rebuilt 383 (my first engine rebuild).
It certainly seems very doable, even for someone like me who has never gone beyond trans pan and filter on a 727.
So far, keep park rod, add 904 valve body after elongating that hole in the plate. Thanks for the pics!!!
Harry
1968 Road Runner
1975 Scamp
Re: 904 valve body in 727 Transmission [Re: John_Kunkel] #2744251
02/18/20 01:00 PM
02/18/20 01:00 PM
moparx Offline
moparx  Offline
i forgot about that center bolt hole john.
thanks for clarifying that point. up
beer
Re: 904 valve body in 727 Transmission [Re: roadrunnerh] #2744364
02/18/20 05:45 PM
02/18/20 05:45 PM
Rio Linda, CA
Rio Linda, CA
Just a FYI, the configuration of the case around the accumulator changed in '71; a '75 VB will fit and function in a '68 case but the accumulator won't work as originally intended i.e. initial engagement of Drive will be more harsh.
Re: 904 valve body in 727 Transmission [Re: John_Kunkel] #2744379
02/18/20 06:50 PM
02/18/20 06:50 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
sorry to hijack thread but, john kunkel, years ago you had a site that had soooo many tips for 904/727. does that site still exist? do you have a really thick book of tips to sell? i want one if you do?
Re: 904 valve body in 727 Transmission [Re: John_Kunkel] #2744451
02/18/20 11:11 PM
02/18/20 11:11 PM
Pittsburgh, PA
Pittsburgh, PA
Thank you for sharing your wealth of information on the 727 and 904!
I was just going to use this '68 727 with my 383 swap and started thinking about the N S switch issue. I thought I would get some info on the possibility of using the VB from my '75 904 (that I drove) with the added bonus of the partial kick down.
Filing a hole I can handle, but now I'm wondering if the harshness would be "too" harsh. I know it's hard to quantify "harsh".
Perhaps I should try to find a more suitable replacement VB?
There is so much misinformation around the neutral safety switch compatibility. I've read some people saying to just use the switch your wiring harness requires.
Harry
1968 Road Runner
1975 Scamp
Re: 904 valve body in 727 Transmission [Re: rbkt65] #2744453
02/18/20 11:12 PM
02/18/20 11:12 PM
Pittsburgh, PA
Pittsburgh, PA
no worries.
Harry
1968 Road Runner
1975 Scamp
Re: 904 valve body in 727 Transmission [Re: rbkt65] #2744623
02/19/20 02:33 PM
02/19/20 02:33 PM
Rio Linda, CA
Rio Linda, CA
That was the old Photobucket site, no longer accessible.
Re: 904 valve body in 727 Transmission [Re: roadrunnerh] #2744626
02/19/20 02:37 PM
02/19/20 02:37 PM
Rio Linda, CA
Rio Linda, CA
To use the 3-prong NSS with the '68 VB, simply swap the rooster combs. The '75 PTK module can be swapped onto the '68 VB and will function but the 40 mph limit function won't work.
Re: 904 valve body in 727 Transmission [Re: John_Kunkel] #2744633
02/19/20 03:09 PM
02/19/20 03:09 PM
Pittsburgh, PA
Pittsburgh, PA
So to be clear (bear with me) If I swap the rooster comb from the 75 904 into the 68 727, I will have reverse lights, and the car will not start in gear. What 40 mph limit function are you referring to? Thank you!
Harry
1968 Road Runner
1975 Scamp
Re: 904 valve body in 727 Transmission [Re: roadrunnerh] #2744658
02/19/20 04:36 PM
02/19/20 04:36 PM
Rio Linda, CA
Rio Linda, CA
Yes, as long as you use the 3-prong NSS and wire it correctly. Along with the rooster comb you will need the end plate from the '75 (see pic below) to limit the travel. Elongate one screw hole.
Quote
The '71-later PTK module has a limit valve to prevent PTK above 40 mph, this valve is ineffective on earlier VB's so you may get PTK above 40 mph.
Re: 904 valve body in 727 Transmission [Re: John_Kunkel] #2746289
02/24/20 11:39 PM
02/24/20 11:39 PM
Pittsburgh, PA
Pittsburgh, PA
Here's a pic of my '75 904. The rooster comb and the end plate I need to remove.
Any tips?
Remove e clip on selector shaft,
Remove 10 7/16 bolts to remove valve body
Harry
1968 Road Runner
1975 Scamp
