Re: Please, Help me pick a cam
[Re: Dodge]
#274449
04/02/09 09:59 PM
04/02/09 09:59 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
I had a 509 in my 70 Cuda with a 440. It must not of had enough compression. It was a real dog. I put a Comp Cam XE274H and it was like night and day. Very happy. It pulls hard from the bottom rpms to top.
So is this a good choice? Jim
[Re: mark7171]
#274452
04/02/09 11:05 PM
04/02/09 11:05 PM
Posts: 4,179 California
mickm
California
If a thumping shaft is getting shoved in a mill hole, It better be thick and bumpy.
that's what my wife says, but i don't pay attention to her...
[Re: mickm]
#274453
04/02/09 11:18 PM
04/02/09 11:18 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
XE268 or similar. It works very well from idle up. I think any smaller and you're leaving power on the table for no reason. But I also think the 274 is too much for it.
[Re: Brian Hafliger]
#274456
04/04/09 10:58 AM
04/04/09 10:58 AM
1fastrunner
That rpm range seems a little high for me. As far as the stealth heads, I'm not porting at this time, maybe milling them to get to 10 compression. I have a 4-speed with 3.23 gears, and my rpm range is probably above 1000-3000 for most of my street driving. Some of the Comp cams I'm looking at are: 256H, 260H, XE262H, 265DEH, 268H, & 275DEH. I'm not eliminating any other brands or grinds, but these are just from looking at their site. Jim
[Re: 1fastrunner]
#274457
04/04/09 11:33 AM
04/04/09 11:33 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I run the XE262H in my 383, which is slightly "bigger" than the stock magnum cam. It performs very well for the street. With 275/60/15 on the rear, a 727 and 3.73 gears I can blow the tires off from an idle, from a stop. So, I'd think the XE268H would work about the same in a 440 as the XE262H in my 383... The 262 gives my 383 a nice noticeable muscle car idle.
The XE274H cam may work good for you too if your compression is at least a true 9 to 1. ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Junky]
#274458
04/04/09 01:24 PM
04/04/09 01:24 PM
Dont overlook the Lunati Voodoo cams. Cam's have come a long way in 40 years. And the 509 is a great cam still. But its not a nice street cam!The .475/.494 would be a great choice for your combo. It's low duration. Keeps the pressure and vacuum up. It doesnt need alot of gear either. I have it in my 72 New Yorker with 373's and i'll tell ya. It aint your grandpa's New Yorker! Great street cam!!!! ![](/ubbthreads/images/graemlins/drool5.gif)
#274459
04/04/09 10:27 PM
04/04/09 10:27 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd look at the voodoo 60303, 60304, or comp XE275HL
[Re: 1fastrunner]
#274460
04/05/09 01:37 AM
04/05/09 01:37 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The Lunati 60303LK 226/234 @ 0.050, 0.494"/0.513" lift, 110 LSA would be a good pick, and it is one of the least expensive cam/Lifter kits at $180. If you are going for more power, the Comp XE275HL cam is really nice, 231/237 @ 0.050", 0.525"/0.525", 110 lsa, and the cam/lifter kit is only $210 from summit racing. The Hughes HEH2832BL3 cam (228/232 @ 0.050", 0.524"/0.540" lift 110 lsa) should give you the torque of the milider Lunati cam and near the HP of the Comp cam, but it is the most expensive at about $270 for cam and lifters. Anyhow thats my ![](/ubbthreads/images/graemlins/Twocents.gif)
