Re: Oil leak- HELP!
[Re: NITROUSN]
#2744492
02/19/20 08:19 AM
02/19/20 08:19 AM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
I put some gas in a squeeze bottle and poured/squeezed it in the overflow hole to see if it drained thru this hose, it didn’t. Remember, this hose has a removable cap but isn’t shown in the picture. Can’t figure why the Chrysler engineers designed a capped drain hose if it isn’t intended to drain anything. BTW, the cap was split which allowed this fluid to drain. I’m guessing there was about 8 ounces on my floor. Can't answer why there is oil. Behind the plastic fender liner I believe there are fuel vapor containment components for emissions. It could be a service port for test equipment hence the cap.. Just a guess. I also thought of what has been mentioned about a filler neck water drain. Looks like a trip to a dealer to see if they can advise once seen. Has the car ever been worked on or wrecked in that area?
Re: Oil leak- HELP!
[Re: Mopar Grandpa]
#2744500
02/19/20 08:39 AM
02/19/20 08:39 AM
Mopar Grandpa
Sebring, Florida
Mystery solved, sorta. I went to my local dealership and had the parts guy pull up the fuel delivery schematic on his computer screen. The top of this “drain tube” is plumbed into the neck of the fuel filler tube close to the gas door. It showed the line extending down, like in the picture I posted, but it’s not tied into anything. The parts guy had no idea what function this line served and I can only assume it might have something to do with the vacuum seal for the gas door??? Concerning the “oil”; the day before noticing the leak I poured some Lucas Oil injector cleaner in the filler tube which is clear and somewhat oily. I suppose it never reached the tank but got into this mysterious “drain tube”. Btw, the overflow hole behind the gas door just dumps any water, gas spill, etc. on top of the inner quarter panel liner. Thanks for everyone’s input.
Re: Oil leak- HELP!
[Re: Mopar Grandpa]
#2744504
02/19/20 09:02 AM
02/19/20 09:02 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
If you want to add anything to the fuel tank you have to use the funnel found under the spare tire cover. If it's not there you can make a funnel from a bottle of Techron fuel additive. After it's empty just cut away the bottom of the bottle, makes an awesome funnel, easier to use than the overpriced thing they furnish.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
