Head bolts for 72 440 #2744118
02/17/20 11:33 PM
02/17/20 11:33 PM
Maine
E
exile5700 Offline OP
E
Maine
I am getting ready to install my Edelbrock aluminum heads. What is best. Bolts or studs? 440 motor. Was thinking ARP studs but looking for advice. Thank you.
Re: Head bolts for 72 440 [Re: exile5700] #2744144
02/18/20 02:25 AM
02/18/20 02:25 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
what compression ratio ?
Re: Head bolts for 72 440 [Re: calrobb2000] #2744195
02/18/20 10:05 AM
02/18/20 10:05 AM
Maine
E
E
Maine
I believe it will be 10 to 1
Re: Head bolts for 72 440 [Re: exile5700] #2744305
02/18/20 03:33 PM
02/18/20 03:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
arp bolts will do what you want.
Re: Head bolts for 72 440 [Re: exile5700] #2744350
02/18/20 04:57 PM
02/18/20 04:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
If your using the RPM heads stock bolts work fine, I do add harden head bolt washers to them though work up
Summit offers several replacement kits, make sure they come with the washers for the aluminum heads also scope
Re: Head bolts for 72 440 [Re: Cab_Burge] #2744560
02/19/20 11:44 AM
02/19/20 11:44 AM
Maine
E
E
Maine
Thank you
