torque converter balance #2744320
02/18/20 03:58 PM
02/18/20 03:58 PM
italy
antonellomopar Offline OP
italy
Hello
I had the 727 trans redone on a friends 69 Charger with a matching 383 hp. By mistake I have received a torque converter for a 440, with an external balance. I know that the 383 is internal balance, and it doesn't have the weights welded on. Since sending back to the US would be very expensive, can i simply grind the weights off the existing converter? Thank you for the help
Re: torque converter balance [Re: antonellomopar] #2744326
02/18/20 04:05 PM
02/18/20 04:05 PM
Avondale AZ
Prodart440 Online work
Prodart440  Online Work
Avondale AZ
Yes, just make sure it's not going to leak.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: torque converter balance [Re: Prodart440] #2744336
02/18/20 04:31 PM
02/18/20 04:31 PM
A727Tflite Offline
A727Tflite  Offline
Post a picture of the weights in question - there are balancing weights and then there are external balancing weights.
You don’t want to grind off weights used to balance the converter.
Re: torque converter balance [Re: Prodart440] #2744341
02/18/20 04:45 PM
02/18/20 04:45 PM
italy
italy
here is a pic
Re: torque converter balance [Re: antonellomopar] #2744343
02/18/20 04:47 PM
02/18/20 04:47 PM
A727Tflite Offline
A727Tflite  Offline
Yep - external weight.
Carefully cut if off. Stop short of the spot weld. Hand file from there.
Re: torque converter balance [Re: A727Tflite] #2744375
02/18/20 06:24 PM
02/18/20 06:24 PM
italy
italy
Transman, thank you for the help...appreciate very much. Will do as you suggested
Re: torque converter balance [Re: antonellomopar] #2744405
02/18/20 07:55 PM
02/18/20 07:55 PM
A727Tflite Offline
A727Tflite  Offline
Prego.
