Billet main caps #2744189
02/18/20 09:47 AM
02/18/20 09:47 AM
412 SB Duster Offline OP
I'm in need of a new set of 4 bolt Billet caps for a R3/Resto block. I have a set on order from ProGram(Billet speedworks)
but they are 4 weeks out plus the line bore time so i'm just throwing this out there to see if i can find new uncut set.
Just looking to improve timing at this point.
Al
Re: Billet main caps [Re: 412 SB Duster] #2744209
02/18/20 11:01 AM
02/18/20 11:01 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Al...
There is a guy who posts as “ Rocket” on here sometimes and more often on for A bodies only who might have those caps
Don
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Billet main caps [Re: B3422W5] #2744225
02/18/20 11:42 AM
02/18/20 11:42 AM
Thanks Don i'll look him up.
Al
Re: Billet main caps [Re: 412 SB Duster] #2744307
02/18/20 03:39 PM
02/18/20 03:39 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have a set of Milodon billet caps for the 340 main , but they are splayed outer bolts.
It would take some creativity to make work , but they are going cheap.
Re: Billet main caps [Re: tubtar] #2744542
02/19/20 10:48 AM
02/19/20 10:48 AM
I appreciate the offer, i'm sure someone can use them. Just don't see that as a good idea in my case.
I'm a little surprised that no one has set on a shelf some where, but we are talking about a small block mopar frown
Al
Re: Billet main caps [Re: 412 SB Duster] #2744607
02/19/20 01:46 PM
02/19/20 01:46 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call Kent Ritter he should have what your looking for
