1970 roadrunner castle nuts upper and lower ball joint #2741232
02/09/20 02:04 PM
02/09/20 02:04 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
What is considered correct? Lynch road, nov 28 build, most parts on it are oct-nov date. What it had was tri castles on the uppers that are silver with a trace of black, no rust pits at all after evaporust soak, looked untouched but who knows. The right lower was a tricastle, silver trace of black, looked untouched, by cotter pin and dirt buildup, and is a factory ball joint, right side had a 6 castle nut, ball joint is a replacement, black nut. Is all tri castle correct, or upper tri castle, lowers 6 castle, and should they be the black phosphate. I know my 69 car had tris and 6s, but wondered if it had all tri castle on day one, is that possible? Thanks
Re: 1970 roadrunner castle nuts upper and lower ball joint [Re: 4406bbl] #2743568
02/16/20 02:17 PM
02/16/20 02:17 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 1970 roadrunner castle nuts upper and lower ball joint [Re: gtx6970] #2743809
02/17/20 12:41 AM
02/17/20 12:41 AM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
Thanks, thats what I sent to the plating shop, even filed 2 spares down so the cotter pins fit with new ball joints..in case I never find a good or nos left lower ball joint.
