Re: How do YOU store your clicker torque wrench ?
[Re: justinp61]
#2743225
02/15/20 03:43 PM
02/15/20 03:43 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
unwind to zero. see where the beam type rests ? zero as well. Neither of my clickers go to “zero”, one is 20 fp and the other is 20 ip IIRC. So I undwind them to their lowest setting. I dont have a clicker , one beam & one OLD Snap On dial
[Re: 71birdJ68]
#2743247
02/15/20 05:08 PM
02/15/20 05:08 PM
Posts: 11,655 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Un wind to the lowest setting, per USAF I have 7 different Snappy wrenches, some are 40 years old. Have been taken care of and maintained. This is the correct answer. Not needed or recommended to unwind past the lowest setting.
[Re: dOc !]
#2743374
02/15/20 10:26 PM
02/15/20 10:26 PM
Posts: 43,277 Bend,OR USA
Cab_Burge
I have been told since my first purchase in 1971 of a 1/2 inch Proto clicker torque wrench to always take the tension off of it when not using it I do I bought a Snap On later and I do the same thing with it as well as storing it in the plastic storage it came in All my clicker torque wrenches, 1/4,3/8 and 1/2 inch get stored with no preload on them.
[Re: SportF]
#2743498
02/16/20 11:00 AM
02/16/20 11:00 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Mines a Snap-on digital so I take the batteries out.
[Re: pittsburghracer]
#2743510
02/16/20 11:50 AM
02/16/20 11:50 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Mines a Snap-on digital so I take the batteries out. ... THEN back iNtO your Hobo Fright lites ? So cHeEzY... yours is a beeper ?
[Re: dOc !]
#2743557
02/16/20 01:48 PM
02/16/20 01:48 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Mines a Snap-on digital so I take the batteries out. ... THEN back iNtO your Hobo Fright lites ? So cHeEzY... yours is a beeper ? Vibrates too. You would like that option. Lol.
#2743575
02/16/20 02:24 PM
02/16/20 02:24 PM
dOc !
Florida STAYcation
Mines a Snap-on digital so I take the batteries out. ... THEN back iNtO your Hobo Fright lites ? So cHeEzY... yours is a beeper ? Vibrates too. You would like that option. Lol. Tooooo ? .... it is YOU that picked up that piece not me ... does it have MULTIPLE vibrate settings ? WITCH do you prefer ??!! All I have is a Hobo Fright $9.99 clicker ...
[Re: dOc !]
#2743615
02/16/20 03:29 PM
02/16/20 03:29 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would totally use that on a $50 engine.
[Re: CMcAllister]
#2743632
02/16/20 04:01 PM
02/16/20 04:01 PM
dOc !
Florida STAYcation
I would totally use that on a $50 engine. There you go cMac ... mr negative waves ! WHERE is any 50$ engine ?? I’ve used that Hobo piece about 6 times and I’ve compared it to a beam one ... and it’s dead on.
[Re: dOc !]
#2743637
02/16/20 04:14 PM
02/16/20 04:14 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Chinese tools give me the flu...and a few other ailments.
[Re: 71birdJ68]
#2743931
02/17/20 01:01 PM
02/17/20 01:01 PM
Posts: 3,390 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Un wind to the lowest setting, per USAF Easy way to get a ding from QA and have to send the wrench back to PMEL...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
