Page 3 of 3 1 2 3
Re: Please Help Deciding On Big Block Heads [Re: Cab_Burge] #2742917
02/14/20 05:51 PM
02/14/20 05:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted by Cab_Burge
Originally Posted by 67mprfan
I see the TF heads have small exhaust valves has anyone thought about putting in bigger valves to help with flow
Why do that when you can increase the exhaust duration, if needed work When the exhaust valve opens it has a bunch of cylinder pressure waiting to escape, open it sooner to let it out longer if needed up twocents
The B1 and B1 MC heads(2.40 intake) both have 1.75 exhaust valves is what I'm remembering scope
Not enough room in a wedge combustion chamber , as Cab said, I'll take a larger intake valve over a larger exhaust valve, to large & they touch.
Re: Please Help Deciding On Big Block Heads [Re: Cab_Burge] #2742936
02/14/20 07:01 PM
02/14/20 07:01 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
The B1 and B1 MC heads(2.40 intake) both have 1.75 exhaust valves is what I'm remembering scope [/quote]
Cab I guess my line of thinking is on 516 heads they have small exhaust valves and 1st thing everyone talks about is putting in bigger valves to help it breathe, I know comparing 516 heads to trickflows isn't apples to apples but they are smaller than Indy EZ's and Victors
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Please Help Deciding On Big Block Heads [Re: 67mprfan] #2742944
02/14/20 07:27 PM
02/14/20 07:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
A lot of heads can flow a lot of air with a small valve. Take for example a small block 1.60 exhaust valve on a TrickFlow head. (240 cfm) Keep in mind a 2.02 Edelbrock intake valve out of the box maxes out at 243cfm on my bench. Way off topic but just using this as an example. Many guys would be happy with a 300cfm big block Edelbrock Head.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Please Help Deciding On Big Block Heads [Re: pittsburghracer] #2742949
02/14/20 07:37 PM
02/14/20 07:37 PM
hustlin hoosier Offline
The heads on our motor flow well over 500cfm. Every time we found flow on the intake we got a good result. We have also spent a lot of money and time on the exhaust side with almost no gain. There is very little hp to be found on the exhaust and with headers. I don't think there is 15 hp between the best set of headers out there and the worst set. I would trade valve size from exhaust to intake anytime.
Page 3 of 3 1 2 3
