spray can bare metal color #2742423
02/12/20 09:01 PM
02/12/20 09:01 PM
montreal,quebec,canada
buzz440 Offline OP
buzz440  Offline OP
Hi all, I know this has probably been beaten to death already but....... does anyone know who makes the closest match for the bare metal look in rattle can form.
Later, BUZZ
Re: spray can bare metal color [Re: buzz440] #2742456
02/12/20 11:43 PM
02/12/20 11:43 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Matte clear works good.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: spray can bare metal color [Re: buzz440] #2742480
02/13/20 01:36 AM
02/13/20 01:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Depends on lighting: Is the item at top or bottom of the engine bay?
Are you painting aluminum casting, aluminum sheet, aluminum extrusion, pot metal die casting, cast iron, forged steel, cold rolled steel sheet, hot rolled steel shape? As cast, as machined, as rolled, etc.?
There is a thorough testing of many colors Here
One option for bare steel is to leave the item actually bare metal by applying phosphoric acid, wiping with mineral spirits, and coating with 50-50 Cosmoline-mineral spirits. This may last as long as a year or much more. In case of bare steel, later minor surface rusting is easily fixed by simply repeating the process starting with rubbing the item with Scotch-Brite pad or similar wetted with phosphoric acid.
Before and after photos show treatment of bare aluminum that was deteriorating and showing powdery "white rust" particles. The treatment was dry brushing off the white rust, wet brushing with soapy water, and after drying, application of Henkel Alodine 1201 yellow. The photos were taken after the white rust particles were removed. Alodine is mainly for treating and preserving bare aluminum aircraft parts. It comes in yellow or clear. Can also be used on zinc plating.
I believe a few Mopar bare aluminum parts of the late 1960s-1970s were treated with yellow Alodine or similar. Examples were starter and alternator parts.
Re: spray can bare metal color [Re: kentj340] #2742536
02/13/20 10:40 AM
02/13/20 10:40 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
For bare sheet metal I use a "stainless steel" color but every metal will differ of course.
Re: spray can bare metal color [Re: buzz440] #2742846
02/14/20 01:06 PM
02/14/20 01:06 PM
central il.
second 70 Offline
second 70  Offline
central il.
I used Eastwood Diamond clear satin on all bare metal that was suppose to have a natural look. I tested on old brake lines and compared after painting and couldn't tell painted from non-painted. The hood release cable, hood latches,fuel lines,brake lines,clutch linkage, steering coupler,and I even went back and sprayed some in the lid and painted all the zinc bolts by hand after everything was tightened.
Hardest part is it's hard to see when you spray it on and you have to be careful and trust yourself so you don't over apply and case drips and cloudiness. Just use several light coats.
Re: spray can bare metal color [Re: second 70] #2742871
02/14/20 02:13 PM
02/14/20 02:13 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Seymour Stainless Steel is the bare metal color
Seymour Cast Blast is their darker cast iron color
Seymour Aluma Blast is the aluminum color
IMO, all of the Eastwood paints are just relabled Seymour paints.
Re: spray can bare metal color [Re: burdar] #2742933
02/14/20 06:45 PM
02/14/20 06:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Agreed,
I've used all three of these colors from Seymour paints, with good results. And are IMO the best option for the intended result. BUT,,, make no mistake you CAN tell its painted not bare metal
Re: spray can bare metal color [Re: gtx6970] #2742939
02/14/20 07:14 PM
02/14/20 07:14 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Seymour is what I’ve used 16-048 cast blast. That is the darker cast iron look. Very good coverage.
Re: spray can bare metal color [Re: Suregrip391] #2743617
02/16/20 03:33 PM
02/16/20 03:33 PM
buzz440 Offline OP
buzz440  Offline OP
Has anyone used the..... BARE STEEL paint from in-line tube ? they have it listed on their website for $12.00 seems like this might be the metal match we're all looking for. If anyone has used this product please post your results, is it worth it or stick with Seymours stainless steel finish.
Later, BUZZ
