Spark plug Reading Guru's #2742440
02/12/20 10:16 PM
02/12/20 10:16 PM
California, U.S.A.
Torquemonster440 Offline OP
California, U.S.A.
Hey guys, does it look like the new Accel "shorty" header plugs I'm swapping to will be a hotter plug than my previous NGK'S ? It looks like the ground strap is quite a bit longer on the Accel's. Accel p/n 0416-S. The NGK's are p/n BCP6E S.
The last pic is of the NGK'S after about 200 miles around town and 3 passes. Then I blew a hole in my header primary on pass #3 and had to "upgrade" headers. Now I need header specific plugs, and a custom built wrench to pull my plugs on the passenger side. frown by the looks of this pics I'm lean ..with too much timing to boot. I'm afraid the Accel plugs may exacerbate my lean condition. I know I can tune it out, just looking for some input from some more experienced racers.
Thanks, Dave
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Spark plug Reading Guru's [Re: Torquemonster440] #2742445
02/12/20 10:34 PM
02/12/20 10:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What fuel? Just a quickie id say its not lean honestly but need better pics of top and porcelain, also might change depending on fuel you use
Re: Spark plug Reading Guru's [Re: Al_Alguire] #2742447
02/12/20 10:48 PM
02/12/20 10:48 PM
California, U.S.A.
California, U.S.A.
So Cal 91 swill.. Holley 9380 850dp.. jets square 78's all around [ factory baseline ]. 10.3-1 , Promaxx heads.. Eddie copies. Performer RPM.
Orange box.. timing is all in 37° @1900 rpm.
Re: Spark plug Reading Guru's [Re: Torquemonster440] #2742518
02/13/20 09:26 AM
02/13/20 09:26 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
when i'm comparing heat range between different plugs I measure how far down the porcelain goes in the body of the plug before it bottoms out. the shallower the colder; the deeper the hotter. I always prefer the tip as far in the chamber as possible without any interference with the piston or valves. I always measure ohms resistance.
Re: Spark plug Reading Guru's [Re: lewtot184] #2742520
02/13/20 09:33 AM
02/13/20 09:33 AM
California, U.S.A.
California, U.S.A.
Good info , thanks.. measure ohms from the plug tip to the electrode?
Re: Spark plug Reading Guru's [Re: Torquemonster440] #2742576
02/13/20 01:55 PM
02/13/20 01:55 PM
How much total timing does it have at WOT, also what is part throttle cruise timing?
I don't see any lines on the last plug on the ground strap for timing work
I like bright and clean on my plugs, not brown or black and with debris on them tsk twocents
Re: Spark plug Reading Guru's [Re: Torquemonster440] #2742578
02/13/20 02:06 PM
02/13/20 02:06 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
yep. I've seen resistor plugs run anywhere from 3500 ohms to 15000+ ohms. some resistance in the secondary wiring is good but I try to avoid anything around 10,000 ohms for the plug and wire. capacitive discharge ignitions need some resistance, inductive ignition seems to be fine with less.
Re: Spark plug Reading Guru's [Re: lewtot184] #2743794
02/16/20 11:20 PM
02/16/20 11:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
on a magneto, over 5k ohms is bad for the coils, so ohms do affect how the plug runs
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
