Hemi head question #2741880
02/11/20 11:02 AM
02/11/20 11:02 AM
Raleigh, NC
Y
Youngblood Offline OP
Y
Raleigh, NC
I have a 472 that was brought in with what was supposed to be Mopar Performance heads. Unfortunately, I am thinking they may be some Chinese knockoff. Did Mopar ever produce a head without the logo on it? Other things that make me think Chinese are the ugly steps about 1/2 inch into each intake port and the atrocious valve job.
Re: Hemi head question [Re: Youngblood] #2741884
02/11/20 11:12 AM
02/11/20 11:12 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I've never heard of any Chinese Hemi head. As far as a head without a logo...could be a Canfield piece?
Is this a crate motor? If so, it's probably one of the standard Cummins built/MP bombs.
Re: Hemi head question [Re: sixpakdodge] #2741889
02/11/20 11:31 AM
02/11/20 11:31 AM
an8sec70cuda Offline
iagree Post some pics so we can see them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi head question [Re: an8sec70cuda] #2741894
02/11/20 12:01 PM
02/11/20 12:01 PM
Raleigh, NC
Y
Y
Raleigh, NC
Head and intake port
Re: Hemi head question [Re: Youngblood] #2741896
02/11/20 12:06 PM
02/11/20 12:06 PM
Raleigh, NC
Y
Y
Raleigh, NC
Exhaust valve, gray area is where it is sealing on the backcut.
Re: Hemi head question [Re: Youngblood] #2741898
02/11/20 12:09 PM
02/11/20 12:09 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Those are Stage V heads.
Re: Hemi head question [Re: sixpakdodge] #2741901
02/11/20 12:21 PM
02/11/20 12:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’ve only had a couple sets of Stage V hemi heads in my shop.
If purchased as “bare heads”, they are very far from being ready to run.
I had flowed one in a semi-finished state way back(no porting), and they were rather unimpressive like that.
It was clear that wasn’t how they were intended to be used.
I’m sure a proper valve job, along some bowl work and blending the cnc’d opening into the runners will perk them right up.
Re: Hemi head question [Re: sixpakdodge] #2741907
02/11/20 12:32 PM
02/11/20 12:32 PM
Raleigh, NC
Y
Y
Raleigh, NC
Re: Hemi head question [Re: fast68plymouth] #2741909
02/11/20 12:33 PM
02/11/20 12:33 PM
Raleigh, NC
Y
Y
Raleigh, NC
Workin on it. Thank you
Re: Hemi head question [Re: Youngblood] #2741916
02/11/20 12:51 PM
02/11/20 12:51 PM
iagree with what they said, lol. Those are very good heads when done right. Probably bought bare and done up by who knows...obviously not very well.
BTW...I don't think there are any Chinese knock-off hemi heads on the market.
CHIP
Re: Hemi head question [Re: an8sec70cuda] #2741925
02/11/20 01:05 PM
02/11/20 01:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
What I’ve seen with regards to stock, or “stock type” Gen II hemi heads is........ they don’t flow as well as what many people think they flow...... without fairly substantial porting done to them.
Stock 559’s with only the valve job touched up are a little over 300@.700.
The MP 559 replacements can be about 15-20 better, depending on which version 559-M it is.
The Ede made MP heads are in the 320 range ootb.
The Indy SR with a VJ and very mild bowl blend is in the mid-330’s.
The basic shapes of the ports are good on all the heads.
So, after they get the seats redone and bowls blended....... if you’re looking for a significant improvement in flow....... they just need to be made “bigger”.
If you’re building something with enough cubes to utilize a bigger head..... the assembled Ede Victors are over 400cfm ootb.
Re: Hemi head question [Re: an8sec70cuda] #2741980
02/11/20 03:18 PM
02/11/20 03:18 PM
Raleigh, NC
Y
Y
Raleigh, NC
Will not mention any names. Professional shop, $30k build. I am not charging enough
Re: Hemi head question [Re: Youngblood] #2741998
02/11/20 03:58 PM
02/11/20 03:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
I totally get where you’re coming from.
I’ve had my hands on some heads off pretty high dollar builds that I wasn’t too impressed with.
Those “what were they thinking” moments.
I wouldn’t mind seeing some pics of the valve job and bowls as they were.
Re: Hemi head question [Re: fast68plymouth] #2742020
02/11/20 05:29 PM
02/11/20 05:29 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Probably thinking I hope the check clears before he realizes what I sold him...
Kevin
Re: Hemi head question [Re: Youngblood] #2742031
02/11/20 06:02 PM
02/11/20 06:02 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Not who I’m thinking off then, he would have charged more than 30k. Lol. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Hemi head question [Re: BANDIT] #2742435
02/12/20 10:00 PM
02/12/20 10:00 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
This is what Stage V heads should look like after they have been prepped properly.
Re: Hemi head question [Re: 469runner] #2742547
02/13/20 11:48 AM
02/13/20 11:48 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Who did the seal groove for you?
Re: Hemi head question [Re: RATTRAP] #2742716
02/14/20 02:39 AM
02/14/20 02:39 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Tim Banning at For Hemi's Only prepped these heads. First class work.
Re: Hemi head question [Re: RATTRAP] #2742723
02/14/20 07:44 AM
02/14/20 07:44 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I have a customer in Dalton Ga that wrote the program and did mine. It saved me a lot of money.
Re: Hemi head question [Re: Hemi ragtop] #2742797
02/14/20 11:08 AM
02/14/20 11:08 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
I just flowed some Hemi heads @ 28in
66 casting 317 CFM @.700 unported
Edelbrock - Intake 424 CFM @ .700 unported
430 CFM with a little bowl work at seat
