Speakers #2741339
02/09/20 07:22 PM
02/09/20 07:22 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
My 69 Charger project is in need of speakers. I had an AM radio with a front speaker. Does any one have a picture of what the speaker looked like and mounted to? Mine was all cobbed up and wired in place. I think it should be a 4 x 10. I picked up an AM-FM factory radio as well as the rear speaker switch and wiring. What size rear speaker does it use and what side does it mount on? Lastly where is a good source for a factory look and fit speakers.
Re: Speakers [Re: NITROUSN] #2741352
02/09/20 07:56 PM
02/09/20 07:56 PM
Dearborn, Michigan
gtxncuda Offline
gtxncuda  Offline
Dearborn, Michigan
The front is a 4X10 as you mentioned. There are a few available on eBag and there are some that actually have two smaller speakers in the 4X10 housing that sound decent (I have one in my Cuda). When buying rears, be careful of the seemingly millions of 6X9 speakers out there now as just about all are 4 ohm, and the factory radios require 8 ohm speakers, and those seem pretty tough to find. I read something about that using the lower resistance (4ohm) can damage parts of the circuitry in the OE radio, however I'm not an authority on OE radios. Good luck! up
1971 Cuda 340 auto
2013 Mustang Boss 302 L/S
1969 Road Runner RM21 440 4 speed
Re: Speakers [Re: gtxncuda] #2741383
02/09/20 09:11 PM
02/09/20 09:11 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks. I was aware that they should be 8 ohm's. Is the rear 6 x 9 for sure? I was hoping to find new as long as they fit and work correctly.
Re: Speakers [Re: NITROUSN] #2741489
02/10/20 09:49 AM
02/10/20 09:49 AM
Dearborn, Michigan
gtxncuda Offline
gtxncuda  Offline
Dearborn, Michigan
The rears are 6X9 in my 69 Road Runner, and were also the same in my 70 GTX. I believe if you have a rear window defroster, the orientation my be different, but the speaker size is still the same.
1971 Cuda 340 auto
Re: Speakers [Re: gtxncuda] #2741694
02/10/20 06:43 PM
02/10/20 06:43 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks for the help. I found a front mount and ordered 2 new speakers from Turnswitch.
http://www.turnswitch.com/
Re: Speakers [Re: NITROUSN] #2741774
02/10/20 11:34 PM
02/10/20 11:34 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
What was used on the front speaker mount plate to dash? It looks like some sort of seal. The plate I have has some gooey residue on it.
