Crankshaft repair??
#2741365
02/09/20 08:32 PM
02/09/20 08:32 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I just purchased a used short block assembly (500ci MP crate engine) that had damaged the thrust bearing. The crank looks to be worn down on the rear of the thrust surface. (a new thrust bearing fits nice in the saddle, but still a lot of end play) I can measure it when I get the engine disassembled, but the crank looks worn there. I suspect the drive shaft was too long. Is this something that can be repaired, or is it junk? It is a 4.15 stroke crank, most likely a $1000 part if bought now. I bought this for the block (Mega block), but might use this rotating assembly if it can be repaired. Thanks, Brian
Re: Crankshaft repair??
[Re: '72CudaRacer]
#2741373
02/09/20 08:52 PM
02/09/20 08:52 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lots of good cranks out there for under 1000.00.
[Re: hemi-itis]
#2741466
02/10/20 02:46 AM
02/10/20 02:46 AM
Posts: 43,274 Bend,OR USA
Cab_Burge
Maybe years ago, none now that I know of. Back before anti ballooning plates where added into converters it was not uncommon to loose the thrust surfaces on the bearings and crankshafts
[Re: Cab_Burge]
#2741484
02/10/20 09:35 AM
02/10/20 09:35 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I've had a couple of cranks repaired by welding up the thrust surface and turning them back down and not had a problem. Not a big deal...local performance machine shop does it for me. Much cheaper than a new crank.
[Re: Twostick]
#2741693
02/10/20 06:43 PM
02/10/20 06:43 PM
Cab_Burge
Me thinks that 6 bolt stroker crankshaft had issues on the wrong converter I.D. on the crank hub As far as I know Mopar has two different converter hub O.D. sizes, 727 and 904 size hubs
[Re: Cab_Burge]
#2741715
02/10/20 07:35 PM
02/10/20 07:35 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Call Shaft Tech for a price to repair it if you can’t get it done locally.
[Re: fast68plymouth]
#2741806
02/11/20 01:38 AM
02/11/20 01:38 AM
Posts: 3,839 N.E. Ohio
6bblFLASH
N.E. Ohio
Call Shaft Tech for a price to repair it if you can’t get it done locally. That's who did mine. Absolutely no evidence of a repair..PERFECT!! However it was expensive, 700 bucks for thrust repair.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2741813
02/11/20 04:20 AM
02/11/20 04:20 AM
Cab_Burge
Call Shaft Tech for a price to repair it if you can’t get it done locally. That's who did mine. Absolutely no evidence of a repair..PERFECT!! However it was expensive, 700 bucks for thrust repair. Sounds like they really don't want to repair crankshafts to me
