The foam float in my Isspro fuel cell sender (the vertical aluminum tube kind, not the swinging arm) is disintegrating and swelling.
It needs to slide freely inside the tube, and also holds a small magnet that actuates the reed switches on a circuit board.
Rather than buy a $100 replacement sender, I was hoping to fix the float. There does not seem to be a service part available.
Any thoughts as to materials I could use to fabricate a new one? It's a half-cylinder about 1" long, 3/4" high with the magnet embedded in the flat side.
It could be electrically conductive (brass shim stock?) because the resistors and switches are on the other side of the PC board.
Would cork stand up to modern E10 gas?
Or maybe coat the existing foam piece with something fuel-resistant but that also won't dissolve the foam...
