Float for fuel cell sender? #2740926
02/08/20 12:24 PM
02/08/20 12:24 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
The foam float in my Isspro fuel cell sender (the vertical aluminum tube kind, not the swinging arm) is disintegrating and swelling.
It needs to slide freely inside the tube, and also holds a small magnet that actuates the reed switches on a circuit board.
Rather than buy a $100 replacement sender, I was hoping to fix the float. There does not seem to be a service part available.
Any thoughts as to materials I could use to fabricate a new one? It's a half-cylinder about 1" long, 3/4" high with the magnet embedded in the flat side.
It could be electrically conductive (brass shim stock?) because the resistors and switches are on the other side of the PC board.
Would cork stand up to modern E10 gas?
Or maybe coat the existing foam piece with something fuel-resistant but that also won't dissolve the foam... work
Re: Float for fuel cell sender? [Re: DrCharles] #2740949
02/08/20 01:58 PM
02/08/20 01:58 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
These guys were helpful when I updated my fuel system.
https://www.harmonracingcells.com/
Re: Float for fuel cell sender? [Re: jbc426] #2741017
02/08/20 05:53 PM
02/08/20 05:53 PM
BDW Offline
BDW  Offline
Got a pic, can’t visualize it
Does it have to be foam?
Re: Float for fuel cell sender? [Re: BDW] #2741025
02/08/20 06:19 PM
02/08/20 06:19 PM
West Plains, MO
West Plains, MO
Sorry, no pics, I clearanced it slightly and put it back in. It's working for now.
No, the float doesn't have to be foam, anything that floats in gasoline and won't disintegrate or absorb it. Fastening the magnet might be a problem if making a brass float though. There are few adhesives that withstand continuous immersion in gas...
Re: Float for fuel cell sender? [Re: DrCharles] #2741066
02/08/20 08:51 PM
02/08/20 08:51 PM
BDW Offline
BDW  Offline
Shouldn’t be any problem, JB Weld Steel Stik is gas resistant.
Get a normal float and glue the magnet on it.
When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical. For wet-surface or submerged water or gasoline repairs, try our SteelStik or WaterWeld
