oil pan sealing
#2741015
02/08/20 05:51 PM
02/08/20 05:51 PM
birdtracker
am I missing something or is there an easy way to seal my oil pan that allows easy access to service rods and mains.Currently I am using black rtv. thanks Birdtracker
Re: oil pan sealing
[Re: DrCharles]
#2741425
02/09/20 10:42 PM
02/09/20 10:42 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
I've never heard of oiling the intake gaskets to help remove them I use a aviation gasket sealer on them to hold them in place and seal the gaskets to make sure they don't allow oil to be sucked into the intake ports between the gaskets, heads and intake manifold or allow the gaskets to weep oil through them into the ports also. That, oil leaking through the gaskets, is another reason I call them "Hemiroid "motors
Re: oil pan sealing
[Re: Cab_Burge]
#2741444
02/09/20 11:59 PM
02/09/20 11:59 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Cab,I shmear oil on the pan rail and oil pan rail,,,,,,,,real thin so it does not stick.Same for the carb bowl gaskets
Re: oil pan sealing
[Re: hemi-itis]
#2741505
02/10/20 10:33 AM
02/10/20 10:33 AM
Posts: 54 lansing mi.
e85mope
lansing mi.
Hemi-itis : I like the crank scrapper. Do you use this in place of a windage tray? Did you make it yourself or did you order it from someone?
