Re: rear end ?
[Re: 76dodgeboy]
#274068
04/01/09 04:54 PM
04/01/09 04:54 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I believe the 8 3/4 rearend did not come out until 1957. This is from a 36 Plymouth. 3.3 gear with an 8 inch ring. Numbers are on the bottom of the drop out.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: rear end ?
[Re: 76dodgeboy]
#274070
04/01/09 08:07 PM
04/01/09 08:07 PM
36PLYM
Lithonia, Ga
I would assume they did, but I do not know a source.
Re: rear end ?
[Re: 76dodgeboy]
#274074
04/02/09 07:44 AM
04/02/09 07:44 AM
36PLYM
Lithonia, Ga
I used a 68 B body rear on the 36. Fit right up, no hassles. Big brakes to. 3.55 gear.
Re: rear end ?
[Re: RodStRace]
#274076
04/02/09 10:58 AM
04/02/09 10:58 AM
Posts: 1,392 Thayer, MO
bohmer2
Thayer, MO
68 Coronet wagon 8 3/4 in mine. Had to change the spring pads (and they need to be redone), but otherwise fits just fine.
Rod
Which disc brake kit is that on that rear, Scarbird? Looks like the rotors are drilled for both gm and mopar patterns?
Re: rear end ?
[Re: bohmer2]
#274077
04/02/09 06:56 PM
04/02/09 06:56 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Rod
PM sent
