rear end ? #274067
04/01/09 04:43 PM
04/01/09 04:43 PM
Iowa
76dodgeboy Offline OP
Iowa
What rear diff is in my 49 Plymouth? Is it an 8 3/4? It has a drop out pumpkin. Thanks
Re: rear end ? [Re: 76dodgeboy] #274068
04/01/09 04:54 PM
04/01/09 04:54 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I believe the 8 3/4 rearend did not come out until 1957. This is from a 36 Plymouth. 3.3 gear with an 8 inch ring. Numbers are on the bottom of the drop out.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: rear end ? [Re: 36PLYM] #274069
04/01/09 05:36 PM
04/01/09 05:36 PM
Iowa
Iowa
Do they make different gears for them?
Re: rear end ? [Re: 76dodgeboy] #274070
04/01/09 08:07 PM
04/01/09 08:07 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I would assume they did, but I do not know a source.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: rear end ? [Re: 36PLYM] #274071
04/01/09 09:22 PM
04/01/09 09:22 PM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
I don't know if Andy Bernbaum has them, but I think it would be easier to get a different axle. I had 4.11 gears in my '49, I am putting in a 8 3/4. Those brakes are under-powered and its more expensive to redo the old brakes on them.
Re: rear end ? [Re: 49wayfarer] #274072
04/01/09 09:30 PM
04/01/09 09:30 PM
Iowa
Iowa
What rearend will fit without being narrowed?
Re: rear end ? [Re: 76dodgeboy] #274073
04/01/09 09:50 PM
04/01/09 09:50 PM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
Try this link http://www40.addr.com/~merc583/mopar/p15pdf/mopar_axle_sizes.pdf
I have an 8 3/4 out of a B body, 68-70, I think the later ones were too wide.
Re: rear end ? [Re: 76dodgeboy] #274074
04/02/09 07:44 AM
04/02/09 07:44 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I used a 68 B body rear on the 36. Fit right up, no hassles. Big brakes to. 3.55 gear.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: rear end ? [Re: 36PLYM] #274075
04/02/09 10:20 AM
04/02/09 10:20 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
68 Coronet wagon 8 3/4 in mine. Had to change the spring pads (and they need to be redone), but otherwise fits just fine.
Re: rear end ? [Re: RodStRace] #274076
04/02/09 10:58 AM
04/02/09 10:58 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Rod
Which disc brake kit is that on that rear, Scarbird? Looks like the rotors are drilled for both gm and mopar patterns?
Re: rear end ? [Re: bohmer2] #274077
04/02/09 06:56 PM
04/02/09 06:56 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Rod
PM sent
Re: rear end ? [Re: RodStRace] #274078
04/05/09 01:40 PM
04/05/09 01:40 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Rod
What disc brake kit is this?
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
