Re: Cal Tracks options
[Re: cryplydog]
#2740802
02/07/20 10:54 PM
02/07/20 10:54 PM
Posts: 4,693 Wichita
GY3
Wichita
They are designed to be used with split Mono's. I tried using with some SS springs initially and the car porpoised badly off the line.
I installed the whole system and now it works properly. Even the Calvert (old Rancho) 9 position shocks work well. Great 60 ft. and much more consistent.
I used the 20" front segment for the sole reason that's what my car came with originally.
[Re: General 68]
#2740840
02/08/20 01:07 AM
02/08/20 01:07 AM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
Hi! I am looking into installing Cal Tracks on a 68 Charger with xhd leaf springs. Mancini offer them in different configurations: 20- 21- and 22" front spring segment. Drag profile and low profile. Wich ones should I use? Mostly street driven, but leaves a lot on the table during launch at the track. 68 Charger comes with 22in segment, I have the drag profile on my 68 Charger
[Re: tubtar]
#2740855
02/08/20 02:52 AM
02/08/20 02:52 AM
CSK
Pattison Texas
based on everything I have read , they will not like the HD leafs. I agree, I have the split mono
[Re: General 68]
#2740860
02/08/20 03:28 AM
02/08/20 03:28 AM
Posts: 2,468 Sydney,Australia
tex013
Sydney,Australia
Hi! I am looking into installing Cal Tracks on a 68 Charger with xhd leaf springs. Mancini offer them in different configurations: 20- 21- and 22" front spring segment. Drag profile and low profile. Wich ones should I use? Mostly street driven, but leaves a lot on the table during launch at the track. I run caltracs with xhd springs , been like that for 8 or 10 years . Had rancho/calvert shocks now have Vikings. On rear . You order the caltracs to suit your spring , XHD should be 22" in yours . Daily driver , serious bracket racer . Would split monos be better , maybe . Wont know until i try them . Not in budget at moment . Been 1.42 sixty . If mostly street i wouldnt get to hung up on monos . Get the best shock you can afford . I am not sure how long monos will hang in there for regular street use plus heavy loads . I carry rear race wheels , spare , trolley jack etc in the trunk when going racing . Place all the other stuff in car Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2740861
02/08/20 03:33 AM
02/08/20 03:33 AM
CSK
Pattison Texas
Hi! I am looking into installing Cal Tracks on a 68 Charger with xhd leaf springs. Mancini offer them in different configurations: 20- 21- and 22" front spring segment. Drag profile and low profile. Wich ones should I use? Mostly street driven, but leaves a lot on the table during launch at the track. I run caltracs with xhd springs , been like that for 8 or 10 years . Had rancho/calvert shocks now have Vikings. On rear . You order the caltracs to suit your spring , XHD should be 22" in yours . Daily driver , serious bracket racer . Would split monos be better , maybe . Wont know until i try them . Not in budget at moment . Been 1.42 sixty . If mostly street i wouldnt get to hung up on monos . Get the best shock you can afford . I am not sure how long monos will hang in there for regular street use plus heavy loads . I carry rear race wheels , spare , trolley jack etc in the trunk when going racing . Place all the other stuff in car Tex 9k miles on my mono's 4050lb car, still good
[Re: CSK]
#2740871
02/08/20 07:03 AM
02/08/20 07:03 AM
Posts: 2,931 A shed in England
Tig
A shed in England
I looked at changing to the Smiths assassin bars too for the same adjustability options but I don't like the that you have to drill a hole through the leaf spring. I feel this could make it weak and bend at that most stressed area. Anyone have any real world experience with these? I stuck with the Caltracs in the end as I know they work.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: BiomedTechGuy]
#2740933
02/08/20 12:50 PM
02/08/20 12:50 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I just bought a pair of +1" ride height Calvert split mono leaf springs and Calvert sliders for my 440+6bbl 70 Roadrunner.. I chose to add SMITH RACECRAFT ASSASSIN traction bars to the combo, because they function in a similar manner as the Caltracs, BUT are a little more adjustable, and appear to be of the UTMOST in detailed build quality and materials. Check out Smith Racecraft Assassin traction bars BEFORE you get Caltracs (Caltracs are very nice) and also consider getting multiple parts to make for the best result, in other words split mono leaf springs, traction bars, and really good rear shocks! This. This isn't with the split monos on, but the ride height is the same. 20" front segment because I already had the extended front hangers for the Super Stock springs that were on it.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Keith Richards]
#2741126
02/09/20 03:34 AM
02/09/20 03:34 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If you already had the springs and we’re just adding bars, that would be one thing. But if you’re buying both components, why in the world would you choose to mismatch a setup instead of buying components that work correctly together?
#2741136
02/09/20 08:29 AM
02/09/20 08:29 AM
Posts: 570 UK
rb446
UK
Go for the mono's which will help reduce weight as well. Now to just fine tune this thing with double adjustable Stange on the rear and single adjust on the front. Same set up on our '69RR except calvert 9 ways/90/10's for now, caltracs worked ok with SS springs previous with mild 440, now with big wedge motor.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
#2741139
02/09/20 09:14 AM
02/09/20 09:14 AM
GY3
Wichita
Go for the mono's which will help reduce weight as well. Now to just fine tune this thing with double adjustable Stange on the rear and single adjust on the front. My shocks seemed to work better when we made them more vertical. I had a guy fab upper mounts to move the tops toward the wheel.
[Re: rb446]
#2741195
02/09/20 12:39 PM
02/09/20 12:39 PM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
Go for the mono's which will help reduce weight as well. Now to just fine tune this thing with double adjustable Stange on the rear and single adjust on the front. Same set up on our '69RR except calvert 9 ways/90/10's for now, caltracs worked ok with SS springs previous with mild 440, now with big wedge motor. I originally had the Rancho's that Calvert sold in mid 2000's and stock springs with small bottom spring removed, that was the thing to do back then and worked well. Maybe the Rancho's are rebranded to Calverts as I think the rancho's were 9 way adjustable as well. What are people doing on original set up of the CT's? I think a 1/4 turn preload on the passenger side and a nickel gap on the driver? My car was going slight left at the hit last time out but then again a few cars were doing that.....
