V band exhaust clamps?
#2740664
02/07/20 01:52 PM
02/07/20 01:52 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I'm upgrading a street/track car exhaust system. I'm thinking of going from SS band clamps to SS V clamps. They are not cheap, seem relatively heavy, but look to clamp/locate/seal well. I wonder fr the different brands are interchangeable. Anybody like or dislike, and any up or downsides I should take into account. I understand they were invented/patented by Zeppo Marx of the Marx Brothers in the 30's?
Re: V band exhaust clamps?
[Re: JAMESDART]
#2740713
02/07/20 04:44 PM
02/07/20 04:44 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I bought some cheap ones from Amazon to make part of my exhaust system more easily removed for trans service. Best thing i have done hands down, if my headers weren't coated I would chop the ends off and put these on also.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2740716
02/07/20 04:48 PM
02/07/20 04:48 PM
Posts: 1,169 MI
68shifter
MI
I’ve used several different brands over the years. Like anything you get what you pay for. With that being said Vibrant ones are cheap and seem to hold up well.
Don’t weld in one revolution. Some brands will warp easier.
Most I’ve seen all are a little different where they seal. The steps are different, or the “v” is sometimes a little thicker.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: jcc]
#2740719
02/07/20 04:55 PM
02/07/20 04:55 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I'm upgrading a street/track car exhaust system. I'm thinking of going from SS band clamps to SS V clamps. They are not cheap, seem relatively heavy, but look to clamp/locate/seal well. I wonder fr the different brands are interchangeable. Anybody like or dislike, and any up or downsides I should take into account. I understand they were invented/patented by Zeppo Marx of the Marx Brothers in the 30's? I recently built a turbo system for my '69 Super Bee, and used several brands of clamps and flanges together successfully. Some of the brands of flanges will have self-locating grooves on them, with a male and female side. Those might not be compatible between brands if the grooves have different dimensions. Also a flange with a male groove will obviously not work with a flat flange. I used the flanges and clamps from this place and have been happy with the quality for the price. The clamps are quick-release, which makes assembly and disassembly a bit easier. https://monkeyfabgarage.com/collect...pipe-connectors/products/v-band-assembly
Paul '69 Super Bee 383 EFI Turbo
[Re: jcc]
#2740792
02/07/20 10:06 PM
02/07/20 10:06 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
There are numerous manufacturers of V-Band clamps, & they come in many different configurations - A, B, C, dimensions, etc. The main manufacturers of these are Breeze, R-G Ray, Clampco, etc.
There are V-Bands that clamp two flared ends of pipe together - you do not necessarily need to weld machined ends on your two opposing pipes.
[Re: burdar]
#2740826
02/08/20 12:23 AM
02/08/20 12:23 AM
jcc
Bitopia
Can you explain why you want to change? Have you had issues with the band clamps? I've never used them but was considering it on my Dart. I have three different brands of muffler to try. I'd like to be able to swap out mufflers easily to find the sound I'm looking for. Regular clamps would crush the pipe and make it difficult. Three main reasons in my case. 1. The muffler will be very close to fuel tank/rear diffuser, and I must maintain proper positioning, and felt the v clamps will do that well 2. The needed clamps will be in the vicinity on the intakes for the trunk mounted cooling air intakes, and I'd like to reduce reliably any chance of exhaust fumes getting sucked in by using a well sealing clamp system. 3. When at the track, I'd like an easy changeover solution to take the muffler out of the exhaust path, and v clamps seem better for a reasonably quick solution by just having a v clamp straight pipe replacement. Thanks for all the replies, sounds like they are workable for me.
[Re: jcc]
#2741264
02/09/20 04:05 PM
02/09/20 04:05 PM
jcc
Bitopia
So my perception of "heavy" might not be very accurate in this case. I included on the scale a short piece of typical 2.5" tubing with the band clamp because that is the tubing needed in the band clamp slip joint, and the fact the V clamp reduces the amount of 2.5" tubing needed by approx 1".
ie, the V Clamp weighs less, disregarding the needed SS welder filler needed to install.
1lb .2oz vs 1lb 1.9 oz
[Re: jcc]
#2768306
04/25/20 11:57 PM
04/25/20 11:57 PM
jcc
Bitopia
I'm working on my tailpipes/muffler install. I'm piecing/welding mandrel bends together with v clamp connections where needed. I'm working by myself, on jack stands. The V clamps are a major pain to mock up with only two hands. It really takes two hands to assemble the clamp in place, and then some how you have keep the pipe in the correct position, since the clamp requires a perfect alignment to clamp, its tough.
[Re: moparx]
#2768397
04/26/20 12:13 PM
04/26/20 12:13 PM
jcc
Bitopia
as i have never used band clamps of any type, what has been your experience with using both the "butt" style [two pipes of the same size] and the "overlap" style [where the one pipe is inserted into the mating pipe] ? sorry for semi-hijacking this post. I have used band clamps for years of the overlap style, first on my semi trucks, and then on my cars. They work very well. My choice here on v clamps was I was looking for a more precise repeatable solid connection, since my exhaust is near the fuel cell. My problems in the previous comment I expect to only be an issue while fabbing, and after being welded, I will be able disassemble and re install a lot easier. We'll see.
[Re: moparx]
#2768814
04/27/20 06:20 PM
04/27/20 06:20 PM
Posts: 2,255 IL
furious70
IL
I used V bands in my turbo setup on the Fury. Positive location, can loosen up for wiggle room and not come apart, compact in their size vs other flanges and fastener is tangential to joint which can be really beneficial in packaging depending on your layout.
70 Sport Fury 68 Charger 69 Coronet 72 RR
