A-body Power Brake Booster
#2740336
02/06/20 02:19 PM
02/06/20 02:19 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I am a little embarrassed to ask this but....what would be the correct power brake booster for a 1969 GTS Dart with power drum brakes?
Re: A-body Power Brake Booster
[Re: 6PakBee]
#2740488
02/06/20 08:27 PM
02/06/20 08:27 PM
Posts: 43,541 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
7-1/2 inch rebuildable unit. Shown here with a disc brake master cylinder, but the booster is the same.
JB Rhinehart, Realist
A-Body's RULE!
[Re: rarefish]
#2741457
02/10/20 12:49 AM
02/10/20 12:49 AM
6PakBee
North Dakota
Thanks! I take it yours is a disc brake car also?
[Re: 6PakBee]
#2741516
02/10/20 11:05 AM
02/10/20 11:05 AM
Posts: 2,252 New York
rarefish
New York
Thanks! I take it yours is a disc brake car also? Yes, you are correct...
[Re: moparx]
#2741755
02/10/20 10:12 PM
02/10/20 10:12 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
Dimensions on the back of the booster. Did you mean this pushrod from brake pedal to linkage on the back of the booster???
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: RealWing]
#2741775
02/10/20 11:38 PM
02/10/20 11:38 PM
Posts: 3,393 cheshire, ct
davesmopars
cheshire, ct
isn't 7 1/2 inch brake booster 71 72 a body. I thought 67 to 70 was the smaller one
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#2741913
02/11/20 12:41 PM
02/11/20 12:41 PM
RealWing
Ontario, Canada
isn't 7 1/2 inch brake booster 71 72 a body. I thought 67 to 70 was the smaller one The '69 is definitely a 7-1/2" Jim
[Re: RealWing]
#2742080
02/11/20 08:49 PM
02/11/20 08:49 PM
davesmopars
cheshire, ct
isn't 7 1/2 inch brake booster 71 72 a body. I thought 67 to 70 was the smaller one The '69 is definitely a 7-1/2" Jim i thought 6 1/2
[Re: davesmopars]
#2742103
02/11/20 10:07 PM
02/11/20 10:07 PM
Rhinodart
Rhinotruck
Rhinotruck
The early one is actually 7". I had one on my 67 383 Barracuda, also seen them on 67 Darts. I don't when they switched over, but the 7" is not rebuildable without major work to take the case apart.
A-Body's RULE!
[Re: Rhinodart]
#2742121
02/11/20 11:20 PM
02/11/20 11:20 PM
RealWing
Ontario, Canada
I stand corrected. Got out my big calipers and my original '69 measures 6-1/2" across the case and 7" on the outside of the band. I think this is known as the "Second Generation" booster. The later one measures 7" across the case and 7-1/2" across the outside of the band. This is the "Third generation" booster. Chrysler had a dealer install booster kit p/n 3420972 for '67-'70 Dart and Valiant and '67-'69 Barracuda. It was the larger 3rd generation (7-1/2" ) booster. Jim
[Re: RealWing]
#2742189
02/12/20 09:53 AM
02/12/20 09:53 AM
Posts: 19,388 north of coder
moparx
thanks Jim! both rods. the one sticking out from the back of the booster and the linkage [flat one] rod shown. Thank you again !
[Re: RealWing]
#2742200
02/12/20 11:03 AM
02/12/20 11:03 AM
Rhinodart
Rhinotruck
Rhinotruck
I stand corrected. Got out my big calipers and my original '69 measures 6-1/2" across the case and 7" on the outside of the band. Jim Does your band have the bolt like shown above?
A-Body's RULE!
[Re: Rhinodart]
#2742244
02/12/20 12:47 PM
02/12/20 12:47 PM
RealWing
Ontario, Canada
Hope these photos help. Let me know if you need anything else Jim
[Re: moparx]
#2742604
02/13/20 03:21 PM
02/13/20 03:21 PM
6PakBee
North Dakota
PERFECT ! Thank You Sir ! X2! Pushing my luck, does anyone have a picture of the horizontal and vertical braces mentioned in the installation instructions?
[Re: 6PakBee]
#2742837
02/14/20 12:45 PM
02/14/20 12:45 PM
RealWing
Ontario, Canada
PERFECT ! Thank You Sir ! X2! Pushing my luck, does anyone have a picture of the horizontal and vertical braces mentioned in the installation instructions? Yup!!!!!!
