Hub Eccentric Rings? a must? #2739366
02/03/20 03:44 PM
02/03/20 03:44 PM
usa
Mopar1970440 Offline OP
usa
An old timer I work with says all wheels with a larger diameter wheel hub then the vehicle actually has must have a hub eccentric ring to take up the gap/space , If not....he says the lug nuts will loosen up. Is this true? I have been running aftermarket wheels Cragers, centerlines, weld draglites ) with larger diameter hubs then what was actually on the vehicle of mine in the past years and never had lugs or wheels go loose, was I just lucky?
Re: Hub Eccentric Rings? a must? [Re: Mopar1970440] #2739367
02/03/20 03:48 PM
02/03/20 03:48 PM
AndyF Offline
AndyF  Offline
Most of the time OEM engineers use a hub centric design. It is just good engineering practice. The aftermarket generally ignores it since it is cheaper to make a one size fit all wheel. When I design custom brake kits I make them hub centric and when I buy custom wheels I make them hub centric. But as you pointed out, there are lots and lots of cars running around with cheap Crager wheels with giant center holes.
Re: Hub Eccentric Rings? a must? [Re: AndyF] #2739369
02/03/20 04:01 PM
02/03/20 04:01 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Hub centric IMO is needed when an aftermarket wheel is not lug centric with shank lug nuts.My brick is street strip,gets over 1000 miles cruising every season and on a good year I get 50 passes at the track at almost 150 mph......so far. If using stock style rims and lugs the hub centric would be desirable. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hub Eccentric Rings? a must? [Re: hemi-itis] #2739383
02/03/20 05:54 PM
02/03/20 05:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I made some centric rings for my Centerline wheels
Re: Hub Eccentric Rings? a must? [Re: CSK] #2739392
02/03/20 06:45 PM
02/03/20 06:45 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
hub centric rims not a must tight lug nuts a must.
Re: Hub Eccentric Rings? a must? [Re: Mopar1970440] #2739397
02/03/20 06:51 PM
02/03/20 06:51 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
For what it's worth, we have lug-centric steel wheels that my wife's snow tires are mounted to, and I use a hub centric ring on them.
Earning every penny of that moderator paycheck.
DBAP
Re: Hub Eccentric Rings? a must? [Re: not_a_charger] #2739398
02/03/20 07:04 PM
02/03/20 07:04 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
kinda like a belt & suspenders ?!?!? . . . . the aftermarket aluminum wheels I got for my Journey for winter tires, came with a hub centric adapter piece for the wheel to fit like a OE piece . . .
Re: Hub Eccentric Rings? a must? [Re: stumpy] #2739400
02/03/20 07:09 PM
02/03/20 07:09 PM
Kirkland, Washington
Pacnorthcuda Offline
Re: Hub Eccentric Rings? a must? [Re: Pacnorthcuda] #2739403
02/03/20 07:15 PM
02/03/20 07:15 PM
Grand Prairie,Texas
Grand Prairie,Texas
Pretty obvious.
Re: Hub Eccentric Rings? a must? [Re: stumpy] #2739572
02/04/20 10:17 AM
02/04/20 10:17 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Not all wheels are hub centric. Some are lug centric.
Re: Hub Eccentric Rings? a must? [Re: burdar] #2739581
02/04/20 10:41 AM
02/04/20 10:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
First of all, MANY aftermarket wheels are not hub centric because because to make every design of aftermarket wheel's center bore specific to every manufacturer would be ridiculously cost prohibitive OR the selection would be extremely limited.
"some are lug centric" - well actually ALL are lug centric ... or they wouldn't fit the car now would they !! In reality, they're NOT lug centric, that's just the bolt pattern, but modern manufacturing equipment and processes keep the tolerances tight enough that they could be considered "lug centric".
Re: Hub Eccentric Rings? a must? [Re: Stanton] #2739613
02/04/20 12:15 PM
02/04/20 12:15 PM
moparx Offline
moparx  Offline
a timely topic for me, as i was wondering what place[s] are the "go to" for the purchase of said rings ?
any recommended sources ? [as always, TIA ! boogie]
beer
Re: Hub Eccentric Rings? a must? [Re: moparx] #2739784
02/04/20 09:28 PM
02/04/20 09:28 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Never had an issue not running a hubcentric setup. I've logged at least 100,000mi that way.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Hub Eccentric Rings? a must? [Re: moparx] #2739795
02/04/20 10:03 PM
02/04/20 10:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
I cut these down on my lathe to fit
LINK
Re: Hub Eccentric Rings? a must? [Re: AndyF] #2739806
02/04/20 11:05 PM
02/04/20 11:05 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It's more of an issue with later model stuff that have large diameter wheels and low profile tires.
A tall sidewall tire will absorb some of any potential out of round (not centered) vibration.
Back in the 80's I ran a custom wheel and tire store.
The only hub-centric wheel issues (vibration) that we ever saw were on ultra low profile tire and wheel combos on the more exotic type cars (Porsche 928 S4, etc).
The hub centering rings are a good way to help eliminate the possibilities of vibrations. twocents
Re: Hub Eccentric Rings? a must? [Re: CSK] #2739922
02/05/20 12:18 PM
02/05/20 12:18 PM
moparx Offline
moparx  Offline
beer
LINK
i was thinking about doing just that.
easy to do.
how tight of a tolerance did you use ? i was thinking "tap in fit" [OD] for the wheels, and .003-.005 larger ID for the axle flange hub.
beer
Re: Hub Eccentric Rings? a must? [Re: moparx] #2739938
02/05/20 12:36 PM
02/05/20 12:36 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Here's some I had machined for my TT2's.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Hub Eccentric Rings? a must? [Re: FM3AAR] #2739948
02/05/20 01:06 PM
02/05/20 01:06 PM
moparx Offline
moparx  Offline
how close do those fit the wheel and axle hub ?
beer
Re: Hub Eccentric Rings? a must? [Re: moparx] #2739995
02/05/20 02:35 PM
02/05/20 02:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
LINK
easy to do.
beer
This, yes
Re: Hub Eccentric Rings? a must? [Re: CSK] #2740006
02/05/20 03:10 PM
02/05/20 03:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd recommend a swipe of anti-sieze on them...
The hub-centric aluminum wheels on my Pathfinder required significant persuasion to come off the steel hubs on the rear.
As in, 5-lb hammer with 36" handle.
After cleaning up both surfaces and applying anti-sieze, it's much easier now.
