Because the hole wasn't actually cut, but stamped. When the sheet metal is placed in the die, it will move around. To account for some of the inaccuracy, you make the hole a bit bigger. In reality, its only a small part of the hole that resides along the cross member. Figure a +/- 1/8" placement for mass production, which is probably pretty good for that era. You also need some additional room to get the assemble engine and transmission up into place. The factory used carts that were fixed on track and a conveyor system to hold the body and drop it down on cart. Not a lot of lateral movement, so again, to allow for some tolerances, you make the hole a bit bigger.
