What happened to my PC?
#2738806
02/01/20 08:10 PM
02/01/20 08:10 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
It wouldn't wake up one day. Was working fine the day before. So I held the power button down until it shut off, turned it back on and it took forever, like 7 hours to boot back up. The screen said it was reparing disk errors. So it is working again but is super slow, really super slow. I'm thinking the hard drive failed as I don't hear it wirring anymore.
Re: What happened to my PC?
[Re: Guitar Jones]
#2738817
02/01/20 08:44 PM
02/01/20 08:44 PM
Posts: 15,902 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It wouldn't wake up one day. Was working fine the day before. So I held the power button down until it shut off, turned it back on and it took forever, like 7 hours to boot back up. The screen said it was reparing disk errors. So it is working again but is super slow, really super slow. I'm thinking the hard drive failed as I don't hear it wirring anymore. I'm far from an expert, but maybe malware? You can try ccleaner.com There's a free version and it COULD fix it. I've use that several times over the years, after our IT guy recommended it as a very trustworthy tool.
Facts are stubborn things.
[Re: larrymopar360]
#2738821
02/01/20 08:48 PM
02/01/20 08:48 PM
Guitar Jones
I don't know. I always use protection seriously, I'm very careful with this computer as I use it for all my financial stuff so no weird sites, click bates or unknown email links.
[Re: Guitar Jones]
#2738822
02/01/20 08:48 PM
02/01/20 08:48 PM
Posts: 701 Northern California
lilcuda
Northern California
It wouldn't wake up one day. Was working fine the day before. So I held the power button down until it shut off, turned it back on and it took forever, like 7 hours to boot back up. The screen said it was reparing disk errors. So it is working again but is super slow, really super slow. I'm thinking the hard drive failed as I don't hear it wirring anymore. Your hard drive is dying a slow death. If you don't know how to work on computers, take it to someone who does. The longer it runs, the less chance you have to save data that is on it. It might be possible to clone it to an SSD, which will speed up your computer.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: larrymopar360]
#2738827
02/01/20 08:53 PM
02/01/20 08:53 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
It wouldn't wake up one day. Was working fine the day before. So I held the power button down until it shut off, turned it back on and it took forever, like 7 hours to boot back up. The screen said it was reparing disk errors. So it is working again but is super slow, really super slow. I'm thinking the hard drive failed as I don't hear it wirring anymore. I'm far from an expert, but maybe malware? You can try ccleaner.com There's a free version and it COULD fix it. I've use that several times over the years, after our IT guy recommended it as a very trustworthy tool. CCleaner got hacked a few years ago. I haven't trusted it since. To the OP - run whatever anti virus and spyware programs you have and then back up what you can NOW before the disc dies altogether. If it has a recovery partition you may be able to install a new HD and reinstall the operating system and originally installed programs back to its original state when you bought it. If the system boots up to Windows the HD hasn't died, yet. If you have good system backups of your system then a new hard drive and restore your system from one of those back ups. https://www.howtogeek.com/326742/ccleaner-was-hacked-what-you-need-to-know/
[Re: Sixpak]
#2738829
02/01/20 09:05 PM
02/01/20 09:05 PM
Posts: 132 Colorado Springs
Bens_Coronets
Colorado Springs
You can often 'recover' a failing hard drive (temporarily) with Steve Gibson Research's Spin Rite software. I'd recomend running that on the drive, if it 'fixes' it, duplicate the drive to a new drive. Once they start to go bad, they won't live long even after fixed. https://www.grc.com/sr/spinrite.htm$0.02..... Ben
[Re: Bens_Coronets]
#2738836
02/01/20 09:14 PM
02/01/20 09:14 PM
Guitar Jones
You can often 'recover' a failing hard drive (temporarily) with Steve Gibson Research's Spin Rite software. I'd recomend running that on the drive, if it 'fixes' it, duplicate the drive to a new drive. Once they start to go bad, they won't live long even after fixed. https://www.grc.com/sr/spinrite.htm$0.02..... Ben Thanks I will give that a try. I have a SSD in another PC that already has Windows 10 on it. Is that useable? I've been trying to back this up to the cloud but not having any luck doing that.
[Re: lilcuda]
#2738839
02/01/20 10:02 PM
02/01/20 10:02 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
It wouldn't wake up one day. Was working fine the day before. So I held the power button down until it shut off, turned it back on and it took forever, like 7 hours to boot back up. The screen said it was reparing disk errors. So it is working again but is super slow, really super slow. I'm thinking the hard drive failed as I don't hear it wirring anymore. Your hard drive is dying a slow death. If you don't know how to work on computers, take it to someone who does. The longer it runs, the less chance you have to save data that is on it. It might be possible to clone it to an SSD, which will speed up your computer. This. Your drive is going south. SSD's are cheap so try to find someone to clone the contents over to one for you.
[Re: A12]
#2738844
02/01/20 10:40 PM
02/01/20 10:40 PM
Guitar Jones
It looks like everything is backing up to OneDrive so I can retrieve it later. Thanks for all the help!
[Re: Guitar Jones]
#2738847
02/01/20 10:50 PM
02/01/20 10:50 PM
Posts: 30,455 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Some little told me that BANJOones is leaving out some important details...... His PC worked FINE until he went up to West Virginny! THEN it went cRaZy when he got to LooneyVille !
[Re: AndyF]
#2738903
02/02/20 08:38 AM
02/02/20 08:38 AM
Guitar Jones
I was able to save most stuff. I lost my favorites, some programs I don't use and my photos but I have most of them stored on a photo storage site so not a big deal. Thanks to all for the help.
