Re: O/T three phase motor amperage question [Re: mopardad] #2738562
01/31/20 11:04 PM
01/31/20 11:04 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Originally Posted by mopardad
Originally Posted by Twostick
It begs the question if the fan speed was wrong all along, why a problem now all of a sudden? The fan itself is clean, no crud build up on the blades?
Kevin
Belt wear
Ahhh. I read it wrong. For some reason I thought they changed the pulley size to speed it up or does it have a split pulley like a snowmobile clutch that can be adjusted?
Kevin
Re: O/T three phase motor amperage question [Re: Twostick] #2738598
02/01/20 03:16 AM
02/01/20 03:16 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
It has an adjustable split pulley. The tech tried to figure out what changed. He wasn't happy that he didn't have a " smoking gun". but it's only worth spending so much time on. The old restraunt had recently closed, and the new tenant has been getting it ready to reopen. They might have done something. Or maybe it was the belt.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: O/T three phase motor amperage question [Re: Hemi_Joel] #2738613
02/01/20 08:12 AM
02/01/20 08:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know on our exhaust fan for our warehouse the belt wear can be an issue. Its not a three phase deal but the belt wears and you never notice how much the fan slows down over time. Put on a new belt and the building moans and creaks when the fan comes back to full speed.
68 Barracuda Formula S 340
Re: O/T three phase motor amperage question [Re: Bad340fish] #2738667
02/01/20 11:42 AM
02/01/20 11:42 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Glad to hear.
Re: O/T three phase motor amperage question [Re: Hemi_Joel] #2738722
02/01/20 01:25 PM
02/01/20 01:25 PM
central il.
second 70 Offline
second 70  Offline
central il.
Joel, Sure sounds like the belt wore out and stretched and the quick fix was to adjust pulley to tighten the belt? Would you do that on your car and leave it that way? Might be a good time to replace the belt before it breaks or stretches further. Or at least have a spare near by.
Mike
Re: O/T three phase motor amperage question [Re: Hemi_Joel] #2738751
02/01/20 03:15 PM
02/01/20 03:15 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I am left wondering if some vents blow down too forcefully on particular tables in the resturant?
If there was enough time for the pulley edges to wear out the belt - then it is highly likely there was also enough time for the blades of the fan to get dirty.
Those “wandering flames” due to rusted and split tubes ought to be checked out after re-checking what your net loss would be after insurance if the building were to burn down. Imagine how many attorneys would chase the case if someone were injured of killed.
Re: O/T three phase motor amperage question [Re: 360view] #2738752
02/01/20 03:27 PM
02/01/20 03:27 PM
Minnesota
Minnesota
THe first guy who was out there said there was a new belt in the fan cabinet, which he installed. THe second guy said maybe the pulley was worn, or maybe the 1st belt was worn and the second one was narrower or longer. He just wasn't sure. I'll ask him if the fan was clean and if he inspected the heat exchanger. The new restaurant is opening today, we are going there for supper. I hope it's a hit!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: O/T three phase motor amperage question [Re: wingman] #2740207
02/06/20 03:58 AM
02/06/20 03:58 AM
Minnesota
Minnesota
Originally Posted by wingman
CHECK THE HEAT EXCHANGER BUNDLE
We have 24 of the Carrier gas-fired package units on the roof of the school. After 8-10 winters and countless heat cycles the weld-seams of the heat exchanger tubes will rust and split open, causing the flame to start to rollout and the rollout switch to disable the burner. The blower fan will continue to operate blowing cold air, and the thermostat will continue to call for heat, but the draft fan will lock out so no heat. The safety gas valve they found closed may be programmed to close when the rollout switch trips as a precaution. There should be an LED "flash code" you can use to confirm why it tripped out. Or fire up the unit with the side panel off and watch the burners--if the exchanger is cracked the flame will dance in an unstable way and "roll out" will be pretty obvious. If your unit is 10 years old and it has never been changed it is likely due. If you don't see any actual roll out and the flame looks good, the rollout switch itself could be bad--cheap part and super-simple to replace.
Changing the exchanger bundle out is about a 2-hour job for two competent guys--we do them regularly, so we have gotten pretty fast. The size varies depending on the size of your unit--the larger ones can be cumbersome for 1 guy to handle. Our units are 2001 models and are generally very reliable and pretty simple. If something goes wrong in the wintertime with them, 80% of the time it is the heat exchanger reaching the end of it's life.
Good call on the heat exchanger, it was split!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
