I am in the process of restoring my 69 Charger. I detailed all the wiper linkage and installed it on the car. I am changing over to a 3 speed wiper motor. I have the correct motor link. My issue is I can not put the link on to the motor as it wants to move the linkage to far and the rod hits the upper part of the steering column mount. I am missing the page in my parts manual for the wiper linkage numbers. So my question is this. Is the link from the motor arm to the left pivot different from a 2 speed to a 3 speed? Believe me I have looked and rechecked everything else. My original pictures when I pulled it apart show my assembly to be correct. Help.
Problem solved.
