Rear axle shim install? #2737510
01/28/20 07:39 PM
01/28/20 07:39 PM
BDW Offline OP
BDW  Offline OP
I've been fighting an annoying vibration and the next step is to change my pinion angle.
Is it as simple as loosening the u-bolts and putting the wedge between the springs and hanger?
Re: Rear axle shim install? [Re: BDW] #2737545
01/28/20 09:56 PM
01/28/20 09:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
It depends on the shim, if it has a hole for the centering bolt you will need to lift the housing up enough to slide them over that bolt head or nut shruggy
Re: Rear axle shim install? [Re: Cab_Burge] #2737547
01/28/20 10:04 PM
01/28/20 10:04 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yep.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Rear axle shim install? [Re: GoodysGotaCuda] #2737566
01/28/20 11:43 PM
01/28/20 11:43 PM
What angles are you showing? full or part time vibration?
Re: Rear axle shim install? [Re: RapidRobert] #2737601
01/29/20 06:51 AM
01/29/20 06:51 AM
BDW Offline OP
BDW  Offline OP
Seems to be part time, hard to tell, but it gets really bad above 65mph.
I’ve had the the tires and driveshaft balanced twice, with no difference.
Here’s where I started, but have since shimmed tranny up so it’s now 2 degrees down.
Again no change, so next step is to shim rear end down 3 degrees.
Re: Rear axle shim install? [Re: BDW] #2737615
01/29/20 08:19 AM
01/29/20 08:19 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've slept since this, but wouldn't you want to nose the diff up 2° so that each yoke is in a parallel plane?
2020 RAM 1500
Re: Rear axle shim install? [Re: GoodysGotaCuda] #2737637
01/29/20 10:24 AM
01/29/20 10:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You want the driveline angle and the pinion angle on parallel planes ON ACCELERATION, a lot of variables determine how much the pinion rotates upward on acceleration, can be upwards of 5 degrees
Re: Rear axle shim install? [Re: DAYCLONA] #2737639
01/29/20 10:46 AM
01/29/20 10:46 AM
BDW Offline OP
BDW  Offline OP
That’s my thinking at this point, it rotates up on accel, so I’ll move it down and see what happens.
Because the vibration does significantly reduce under decel.
Under load at 70mph vibration is bad, when I let off gas and coast the vibs go away.
Re: Rear axle shim install? [Re: BDW] #2737660
01/29/20 11:59 AM
01/29/20 11:59 AM
& you want the angles to be minimal. Yes the pinion will rise & how much depends if it is a DD or driven hard. I had a part time vibration & it turned out the yoke was not far enough into the trans. A slightly longer shaft fixed it.
Re: Rear axle shim install? [Re: RapidRobert] #2737672
01/29/20 12:15 PM
01/29/20 12:15 PM
moparx Offline
moparx  Offline
at what speed was the driveshaft balanced ?
steep gears and OD transmissions don't play well with driveshafts that are not high speed balanced.
beer
Re: Rear axle shim install? [Re: moparx] #2737691
01/29/20 12:44 PM
01/29/20 12:44 PM
A727Tflite Offline
A727Tflite  Offline
Overdrive transmissions have no impact on the prop shaft speed.
In third or overdrive at any given vehicle speed the prop shaft turns at the same speed in either gear.
Engine speed is lower in overdrive than in third, that’s the benefit. Not shaft speed.
Re: Rear axle shim install? [Re: A727Tflite] #2737717
01/29/20 01:42 PM
01/29/20 01:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
In a way they do... most production driveshafts are generally balanced for 3000-3500 rpm, when you add an overdrive transmission along with let's say a 4:10 rear gear, .... a .64 overdrive is now capable of moving the vehicle to a speed of 140-150 mph with engine rpm being the limiting factor, prop speed is now extremely high, one of the reasons most aftermarket overdrive suppliers balance the shaft to 10,000 rpm
Re: Rear axle shim install? [Re: DAYCLONA] #2737732
01/29/20 02:13 PM
01/29/20 02:13 PM
A727Tflite Offline
A727Tflite  Offline
Please read my post again - “at a given vehicle speed”.
No arguement that going faster makes the prop turn faster.
Re: Rear axle shim install? [Re: A727Tflite] #2737928
01/29/20 11:41 PM
01/29/20 11:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, I was making a case for the possible need to look at the driveshaft balance, to rule out possible harmonics
Mike
Re: Rear axle shim install? [Re: GoodysGotaCuda] #2737943
01/30/20 01:03 AM
01/30/20 01:03 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
This is what works for me, every time light load at highway speeds. It would not be the best for a drag car. I am suprised that with the rear at zero and trans 2 down you have an issue, it should be fine, like almost perfect under light load. Is the dana offset left or right, and is engine/trans straight in the car? Just wondering if you may be getting an offset induced vibration.
Re: Rear axle shim install? [Re: DAYCLONA] #2738052
01/30/20 12:11 PM
01/30/20 12:11 PM
moparx Offline
moparx  Offline
Mike
agreed, no matter what speed, the tire/rear gear combo will be turning xxxxrpm.
however, more than once, i have found deep gears and a short tire has caused driveshaft vibrations because the shaft was only balanced at a somewhat low speed.
balancing the shaft at a high speed cured the vibration issue.
just putting this out there as something else to look at if the vibration continues after fixing the driveline angle[s].
beer
Re: Rear axle shim install? [Re: moparx] #2743665
02/16/20 05:29 PM
02/16/20 05:29 PM
BDW Offline OP
BDW  Offline OP
Update for others who may experience this issue.
I tried shimming the rear end down and it made no difference.
I took the shims out and tried a different yoke.
Success!
I can’t believe it, just got back from a vibe free drive and it felt great.
I changed out the yoke with a new u-joint and it worked.
Luckily I had the original yoke from when I pulled the 518 from the junk yard. It was rusted and scarred up, but I dressed it up.
Worst case scenario is it may leak, but I’ll worry about that later.
Another member gave me a tip about the difference between the 2 yokes. I had never seen that mentioned elsewhere.
Apparently the 518 yoke has a slightly different pitch on the splines compared to the 727 yoke,
