1970 HP 440 Intakes #2737536
01/28/20 09:29 PM
01/28/20 09:29 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
How many different castings were used for the 1970 440 HP engines? Looking at casting 2951736, mine has no date code on the top showing, just see a 11x11 on the bottom. Is this the date code as in 11 month 11 day? Would be interested in seeing pictures of original intakes on Superbirds as that is what mine is off of. I was looking for a duplicate of mine for a project and didn't realize how many different ones apparently were used.
Thanks!
Re: 1970 HP 440 Intakes [Re: mopar4ya] #2737640
01/29/20 10:54 AM
01/29/20 10:54 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
2951736 is correct. I have seen them with date codes on top side and bottom side. I assume maybe there was more than one supplier. Or, they changed the date code location sometime during the model year. My guess is more than one supplier. Never studied it close enough to know more. There are several listed on Ebay right now if you would like to compare.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1970 HP 440 Intakes [Re: 70gtx440dana] #2737641
01/29/20 10:59 AM
01/29/20 10:59 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Check the 440source site it did have some casting number info ??http://www.440source.com/intakes.htm
Re: 1970 HP 440 Intakes [Re: RTshaker] #2737976
01/30/20 08:16 AM
01/30/20 08:16 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks, I'll check both places out. Any Superbird guys out there, would like to know what was on your car if it is still a known original.
Re: 1970 HP 440 Intakes [Re: mopar4ya] #2737999
01/30/20 09:36 AM
01/30/20 09:36 AM
MD
floyd Offline
floyd  Offline
MD
Not sure if this will add anything to your quest but here's an NOS manifold I had awhile back.
Re: 1970 HP 440 Intakes [Re: mopar4ya] #2738032
01/30/20 11:11 AM
01/30/20 11:11 AM
Lansing, MI
Lansing, MI
The guys over at Dodgecharger.com ( aero car forum) can likely provide details on the intakes used on Super Birds. I am sure this question has come up before. You might want to
post the question there.
