NP 4spd O.D. transmission used in GM pickups ? #2737407
01/28/20 12:28 PM
01/28/20 12:28 PM
moparx Offline OP
moparx  Offline OP
does anyone know anything about NP 4speed overdrive transmissions used in mid/late 80's - early 90's GM pickups ?
if so, were these the same transmissions used in dodge pickups ?
similar but different case to bellhousing bolt patterns ?
same or different output shaft spline count ?
my one buddy was talking about a transmission another guy had, and said it was a new process 4spd overdrive out of a chevy pickup.
anyone have anything on this animal ?
as always, TIA ! boogie
beer
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: moparx] #2737509
01/28/20 07:35 PM
01/28/20 07:35 PM
Guitar Jones Offline
The New Venture 4500 was used in GM trucks. There are differences though. I know the input shaft is shorter and some may have different ratios. A google search on the NV 4500 will turn up quite a bit of information on them.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: Guitar Jones] #2737518
01/28/20 08:20 PM
01/28/20 08:20 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
From what I've heard, yes the 833od was available in 80s gm trucks with a diesel. I saw a photo of one and it appeared to have a transfer case adapter on it.
Id imagine splines are typical GM stuff.
Its not that surprising really, New Process sold lots of stuff to everyone.
Angry white pureblood male
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: moparx] #2737524
01/28/20 08:50 PM
01/28/20 08:50 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: jerseybud] #2737646
01/29/20 11:15 AM
01/29/20 11:15 AM
moparx Offline OP
moparx  Offline OP
thanks for the info guys ! bow
i'll look up the New Venture 4500 for info.
the article link you posted about the bellhousing possibly being a weird bolt pattern was interesting. thanks !
my buddy was thinking of putting this in his 58 chevy impala.
beer
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: moparx] #2737676
01/29/20 12:21 PM
01/29/20 12:21 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
If it's a 5 speed overdrive then its likely the NV4500. This has a granny first gear, not something you want to put in anything but a truck.
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: 73MagDuster] #2737681
01/29/20 12:29 PM
01/29/20 12:29 PM
moparx Offline OP
moparx  Offline OP
i'm pretty sure it's only a 4speed, thus my question.
beer
Re: NP 4spd O.D. transmission used in GM pickups ? [Re: moparx] #2738321
01/31/20 07:05 AM
01/31/20 07:05 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
