Seeking 72 'Cuda grille restoration advice #2736891
01/26/20 08:32 PM
01/26/20 08:32 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'd like to pull the grille on my car and go through restoring it. That said, I have a few questions.
  • What is your favorite trick for removing the silver paint from a grille? Chemical? Light blasting?
  • Is the plastic textured, or does the grille get its texture from the paint?
  • What are the paint codes, or similar codes, that could be used for both the silver and orange?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Seeking 72 'Cuda grille restoration advice [Re: GoodysGotaCuda] #2736906
01/26/20 09:26 PM
01/26/20 09:26 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I know this doesn’t help but I remember the good old days back in the 90’s you could buy 72 up NOS Mopar cuda grills dirt cheap from Year One!
Re: Seeking 72 'Cuda grille restoration advice [Re: mopargem] #2736917
01/26/20 10:04 PM
01/26/20 10:04 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I sure wish I could! I looked at the new ones at Carlisle last year and just couldn't do it. It's a bit of a bummer for that much money the chrome rectangles aren't included as well.
2020 RAM 1500
Re: Seeking 72 'Cuda grille restoration advice [Re: GoodysGotaCuda] #2736949
01/27/20 12:31 AM
01/27/20 12:31 AM
NY
LTLBEE Offline
LTLBEE  Offline
NY
I used Easy Off oven cleaner in the yellow can to take the paint off my 1970 Cuda grille. It did not harm the plastic.
I sprayed it on the grille and put it in a plastic storage container and let it soak for about an hour.
Do not let the oven cleaner dry on the grille.
Took it out and used a green scotchbrite pad and
small brass brush to get the tight areas.
You usually have to do it a few times to get all the paint off. Wash it with warm water when your done.
Re: Seeking 72 'Cuda grille restoration advice [Re: GoodysGotaCuda] #2737005
01/27/20 10:21 AM
01/27/20 10:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
When I strip Argent off 70-74 Cuda grilles, I always use lacquer thinner and clean white rags, start at one end and work your way to the other end removing all the argent as you go, just give the plastic under the argent some recovery time between applications when you get close to the plastic surface wiping off the argent (pretty much after the solvent is evaporated) as the lacquer can soften the plastic, the factory argent is lacquer based...
the 72-74 Cuda grille will be smooth plastic under the argent in case your considering a color keyed grill (IMHO would look really sharp on your ride)
Mike
Re: Seeking 72 'Cuda grille restoration advice [Re: DAYCLONA] #2737345
01/28/20 08:30 AM
01/28/20 08:30 AM
Woodbridge
Tommy The Chryco Offline
Woodbridge
Agreed
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: Seeking 72 'Cuda grille restoration advice [Re: Tommy The Chryco] #2741143
02/09/20 09:43 AM
02/09/20 09:43 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Any sources for the textured argent silver paint?
Looks like Totally Auto's site is down, that's the only place I knew that sold it.
Is this any good?
https://www.classicindustries.com/p...5MKFQDtr2_snkYgEvnr5vDlQX7hoCZxwQAvD_BwE
or
https://8774paint1.com/products/grille-silver
2020 RAM 1500
Re: Seeking 72 'Cuda grille restoration advice [Re: GoodysGotaCuda] #2741316
02/09/20 06:18 PM
02/09/20 06:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
or
8774paint1 is the new source/supplier of the former Totally Auto line of restoration paints, personally I'd avoid spray bombing it, see if quarts are available?, Charles is very easy to work with regarding personal requests
Pssst....IMHO a color keyed grille and rubber bumpers would really be sharp on your ride
Re: Seeking 72 'Cuda grille restoration advice [Re: DAYCLONA] #2741363
02/09/20 08:29 PM
02/09/20 08:29 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
or
Thanks for the info, I'll reach out to him.
and I haaaaaaate color matched grilles on 'Cudas realcrazy biggrin
2020 RAM 1500
Re: Seeking 72 'Cuda grille restoration advice [Re: GoodysGotaCuda] #2741380
02/09/20 09:05 PM
02/09/20 09:05 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I would try the frank badalson kit, $125 on his site, it used to be a 3 part deal. By the time you go to a paint shop and try to match it you will spend more. If you are going thru all the work may as well get the right paint, the new supplier for totally auto could likely supply it too. It would be hard to get good texture and even color with spraycans.
Re: Seeking 72 'Cuda grille restoration advice [Re: 4406bbl] #2741458
02/10/20 01:15 AM
02/10/20 01:15 AM
Sandy, OR
OE Argent Offline
OE Argent  Offline
Sandy, OR
Or, Go with the original 1 part formula the factory used...
Re: Seeking 72 'Cuda grille restoration advice [Re: OE Argent] #2741530
02/10/20 12:11 PM
02/10/20 12:11 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
That is the best, do you still sell it?
Re: Seeking 72 'Cuda grille restoration advice [Re: LTLBEE] #2741748
02/10/20 09:49 PM
02/10/20 09:49 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
iagree I use this method a lot with great success. Be very careful using lacquer thinner on plastic. It will melt some kinds.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Seeking 72 'Cuda grille restoration advice [Re: moparmarks] #2743326
02/15/20 09:02 PM
02/15/20 09:02 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
My son's cuda is color of car. Have a couple of broken grilles. What are you guys using to glue them together ? He has a nice silver grille but we really hate to strip it and paint....
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Seeking 72 'Cuda grille restoration advice [Re: 4406bbl] #2750575
03/09/20 08:26 PM
03/09/20 08:26 PM
Sandy, OR
OE Argent Offline
OE Argent  Offline
Sandy, OR
Argent Collection
Re: Seeking 72 'Cuda grille restoration advice [Re: OE Argent] #2750616
03/09/20 10:46 PM
03/09/20 10:46 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Nice collection.
Re: Seeking 72 'Cuda grille restoration advice [Re: GoodysGotaCuda] #2751189
03/12/20 09:46 AM
03/12/20 09:46 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Removed it with generic lacquer thinner, did not waste DDL on it. Worked quickly with adequate recovery time
The plastic under the paint is smooth.
I used Totally Auto.
I had three issues with the original grille:
I had a rock hole in the middle upright about the size of a quarter. I backed it with fiberglass mesh tape and layered a mix of acetone and shavings from a donor grille until the hole was filled in and built up slightly higher than the surrounding plastic. I then sanded it smooth.
The other issues were the extensions that support the headlight bezel. Both had cracked and eventually broke entirely off. Backing it with metal and JB weld would work for a while but stress would renew the cracks,
I gave up and bought the new repop. I painted it with the leftover Totally Auto paint from the first rebuilds and put the original chrome rectangles back in. The replacement grille has the orange already on the grille so it had to be masked off to keep it orange.
I am not sure how accurate anything is now. This car has been a driver from when I got it in 1977.
Craig
