Ebody Ashtray Insert #2736253
01/24/20 06:38 PM
01/24/20 06:38 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
I recently purchased an Ashtray Insert from Tony's Parts for my 1970 'Cuda. While restoring the ashtray door cover portion of the assembly I have been trying to figure out how I might install the two bottom rivets (1/8 hollow wall rivets) necessary to mount the insert to the door cover (see pic). Due to the upward angle of the insert it is impossible to get a rivet setting tool squarely in line with the rivets that would allow a uniform peening over of the rivets when struck with al hammer. The best I have come up with is to shorten the rivet setting tool to about 1 inch, that would allow for squarely placing the head of the setting tool on the rivet and using a "C clamp", I might be able to crush the rivet uniformly. Has anyone else installed this insert and if so what type of tool did you use to install the rivets
Re: Ebody Ashtray Insert [Re: Imrare] #2736260
01/24/20 06:46 PM
01/24/20 06:46 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Stumpy, these are not "pop" rivets, they are hollow wall rivets that "mushroom" over in a circular pattern when properly installed.
Re: Ebody Ashtray Insert [Re: Imrare] #2736316
01/24/20 10:10 PM
01/24/20 10:10 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I saw your picture and that is why I deleted my post.
Re: Ebody Ashtray Insert [Re: stumpy] #2736427
01/25/20 10:19 AM
01/25/20 10:19 AM
MD
floyd Offline
floyd  Offline
MD
Re: Ebody Ashtray Insert [Re: floyd] #2736443
01/25/20 11:23 AM
01/25/20 11:23 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Wow, that is definitely the tool I need. Looks very similar to using the "C clamp" method I suggested and described above. Thank you. At least now I know where to get the tool if that is the route I end up taking. I may buy it, used it for my ashtray and sell it. Even if I get back half what it costs, that's something. Thanks again.
Re: Ebody Ashtray Insert [Re: Imrare] #2741523
02/10/20 11:34 AM
02/10/20 11:34 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Update – thanks “floyd” for the link to another forum site that lead me to this tool.
I tried the “C-clamp” method and it did not work…those rivets are much harder to crush than I thought they would be. However, not wanting to compromise on the OE quality of the installation of my ashtray insert, I “bit the bullet” and purchased the Hanson HS-42E rivet squeezing tool ($145.00) directly from Hanson (pic below). This tool has a 4” reach and a 2 inch gap. Along with the rivet squeezer you will need to purchase a “head” and “tubular roll” squeezing die. The items I purchased were #CA2004-9, 3/8” head die and #CA2005-13, 7/8” “roll” die ($16.00 ea). The tool is of very high quality and works perfectly for achieving an OE look on the ashtray insert installation. A note here on use of the tool, the “ram” on the tool is adjustable so that you can customize it for the rivet and die you are using. There were no operating instructions provided with my tool. It took a little thinking and studying the tool until I realized, twisting the “ram” counter-clockwise lengthened the ram and clock-wise shortened it. With these dies to have the proper squeeze”, you will have to have the ram extend ¾” (with the handle fully down). Because of the 2” heat shield on top of the ashtray, you will not be able to insert the tool into the ashtray insert with both dies installed on the tool. It takes a little “jiggling” around but the process I used was to not install the 7/8” die until I inserted the front part of the tool in the ashtray and moved the back part of the tool into position (head of rivet). Then I reached into the ashtray and inserted the 7/8” “roll die” into the front of the tool, then extended the “ram” to just make contact with the rivet head to hold it in place, made sure my “roll die” was seated in the rivet and squeezed. The results were exactly what I was looking for.
I am finished with the tool and plan to eventually sell it and the dies at a little discount on ebay to others wanting it for the same purpose. I figure the discount then will be the ultimate cost of getting insert installed correctly. Then whoever buys the tool can use it and pass it on at a slight discount to someone else and on it goes…
20200209_130910_resized.jpg20200209_130949_resized.jpg20200209_131004_resized.jpg20200209_131017_resized.jpg
Re: Ebody Ashtray Insert [Re: Imrare] #2741525
02/10/20 11:37 AM
02/10/20 11:37 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Hear are some other pics of the tool.
Re: Ebody Ashtray Insert [Re: Imrare] #2741540
02/10/20 12:44 PM
02/10/20 12:44 PM
MD
floyd Offline
floyd  Offline
MD
Excellent results and a great post!
Re: Ebody Ashtray Insert [Re: Imrare] #2741542
02/10/20 12:46 PM
02/10/20 12:46 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Hey Bob, that turned out nice. thumbs
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
