Big Block Water Pump #273542
04/01/09 12:55 PM
04/01/09 12:55 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
71 Cuda 383 auto. The rad hoses are both on the drivers side. Its a 22". I want to replace with an alum rad, but most of the bottom hose locations are on the pass side. The top is not a big deal, just a hose change, but the bottom, is a water pump housing change. Did they make big block housings with the outlet on the pass side?
Grandma always said I had "hands of gold"!
Re: Big Block Water Pump [Re: CHRGR69] #273543
04/01/09 12:58 PM
04/01/09 12:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
yes but they are cast iron , should be no problem finding a rad with the inlet on the right side ?
Re: Big Block Water Pump [Re: CHRGR69] #273544
04/01/09 01:00 PM
04/01/09 01:00 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
440 source
or
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Big Block Water Pump [Re: RylisPro] #273545
04/01/09 01:03 PM
04/01/09 01:03 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Beat me to it. BTW they are listed at $89.95.
