Front End Problem
#2734402
01/19/20 11:10 AM
01/19/20 11:10 AM
Posts: 16,153 Mesa, Arizona
dart4forte
Mesa, Arizona
1974 Dodge D100 Stepside. Last fall I lowered the truck by using the B100 van lower control arms and doing an axle flip in the rear. At the same time I rebuilt the the front end replacing bushings, ball joints, steering box, drag link, inner outer tie rods, idler arm and pitman arm. I had the front end aligned and it’s all within spec. I have a problem with turning left and right. In both instances when turning the wheels the tires want to tuck under and at a point stop rolling. The truck actually drags the front tires in the turn until I begin to straighten out. Any ideas?
Abe Lincoln
Re: Front End Problem
[Re: 1E2C]
#2734503
01/19/20 02:51 PM
01/19/20 02:51 PM
dart4forte
Mesa, Arizona
Ackerman angle. Yours is so heavily modified I have no specifics, but when I rebuilt the front end on my 84 in a factory configuration I accidentally installed the center link backwards. It acted much the same and took quite a while to figure out. This brings back my autos days. Totally forgot about the Ackerman affect. With the front end alignment dead on It makes me wonder now if the drag link is on backward. Just narrowing down the problem. I need to get a picture for comparison.
Abe Lincoln
[Re: 1E2C]
#2734599
01/19/20 06:38 PM
01/19/20 06:38 PM
dart4forte
Mesa, Arizona
So what was your solution. I went out and looked at the drag link. I can’t see how it could be installed backwards
Abe Lincoln
[Re: dart4forte]
#2734622
01/19/20 07:30 PM
01/19/20 07:30 PM
Posts: 2,673 Northern MN
1E2C
Northern MN
Mine was installed end for end when I put it back together. This [/b][/i]was[i][b] on an 83 D150, and that's not your model so things may be somewhat different. I could see the difference when they were side by side, (correct vs incorrect), so I took mine out and end for ended it back in - and all was well with the world. I had the front end apart for several months doing the rebuild so that's my excuse - took me too long so I forgetted........ As I recall, (this find was around 5 years ago now), the giveaway was the stud/nut orientation of the tie rods/idler/pitman; correct they angled aft and down and incorrect they angled fwd and down - or vice versa.
[Re: 1E2C]
#2734625
01/19/20 07:55 PM
01/19/20 07:55 PM
dart4forte
Mesa, Arizona
Mine was installed end for end when I put it back together. This [/b][/i]was[i][b] on an 83 D150, and that's not your model so things may be somewhat different. I could see the difference when they were side by side, (correct vs incorrect), so I took mine out and end for ended it back in - and all was well with the world. I had the front end apart for several months doing the rebuild so that's my excuse - took me too long so I forgetted........ As I recall, (this find was around 5 years ago now), the giveaway was the stud/nut orientation of the tie rods/idler/pitman; correct they angled aft and down and incorrect they angled fwd and down - or vice versa. I have a pic of a 75 set up. Mine is definitely off. First giveaway was the grease zirk. Mine face the rear, the truck in the pic face the front. The pitman arm/drag link threads face straight.
Abe Lincoln
[Re: 1E2C]
#2734741
01/20/20 02:21 AM
01/20/20 02:21 AM
dart4forte
Mesa, Arizona
Thanks, I’ll let you know
Abe Lincoln
[Re: dart4forte]
#2734971
01/20/20 04:19 PM
01/20/20 04:19 PM
dart4forte
Mesa, Arizona
Mine was installed end for end when I put it back together. This [/b][/i]was[i][b] on an 83 D150, and that's not your model so things may be somewhat different. I could see the difference when they were side by side, (correct vs incorrect), so I took mine out and end for ended it back in - and all was well with the world. I had the front end apart for several months doing the rebuild so that's my excuse - took me too long so I forgetted........ As I recall, (this find was around 5 years ago now), the giveaway was the stud/nut orientation of the tie rods/idler/pitman; correct they angled aft and down and incorrect they angled fwd and down - or vice versa. I have a pic of a 75 set up. Mine is definitely off. First giveaway was the grease zirk. Mine face the rear, the truck in the pic face the front. The pitman arm/drag link threads face straight. Got a diagram out of an FSM. Correct they installed where the threads face toward the front of the truck angled upward. Mine are installed where the threads are straight up. Obviously wrong. Either wrong drag link or it’s assbackwards.
Abe Lincoln
[Re: 68dodge]
#2735095
01/20/20 10:59 PM
01/20/20 10:59 PM
dart4forte
Mesa, Arizona
Well, hate to admit I didn’t catch this but the drag link is either installed incorrectly or it’s the wrong link. I looked at several diagrams to include the one on the LMC site. Shows the inner tie rods are installed with the threads facing the front of the truck slightly tilted upward.
The tie rods on my truck face directly upward. I’m surprised I didn’t catch this. Surprised the tech that did the alignment last week didn’t catch it.
I’ll pull the drag link tomorrow and see what’s going on
Abe Lincoln
[Re: 1E2C]
#2735148
01/21/20 02:26 AM
01/21/20 02:26 AM
dart4forte
Mesa, Arizona
Yeah, I’ll have it out in the morning and yes I agree, bolt holes should be the way to tell.
Abe Lincoln
[Re: 1E2C]
#2735886
01/23/20 05:23 PM
01/23/20 05:23 PM
dart4forte
Mesa, Arizona
Got it fixed, can’t believe I missed it. Anyway just need to get the toe back in and all set. Thanks for the help.
Abe Lincoln
