No Oil Pressure! Cause Found With Pics #273236
03/31/09 11:29 PM
03/31/09 11:29 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
Looky what I found wrapped around the oil pickup tube and in the pickup!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273237
03/31/09 11:33 PM
03/31/09 11:33 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
What is it? I can only see half the pic that you posted.
Oh I can see it now. I dont see why that would have been used anyway internally on the engine.
Re: No Oil Pressure! Cause Found With Pics [Re: Blakcharger440] #273238
03/31/09 11:34 PM
03/31/09 11:34 PM
Plano, Texas
Dallasdart Offline
Dallasdart  Offline
Plano, Texas
Steel wool? who built the motor...oopsy
72 Dart Swinger 360 Project
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273239
03/31/09 11:35 PM
03/31/09 11:35 PM
This is a 74 slant with 70-80K on it? I am not sure. I got it on the stand and opened the pan.
Here is the bearing from #5 usually the one that craps out first.
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273240
03/31/09 11:38 PM
03/31/09 11:38 PM
Not steel wool, cloth! Here is the #5 journal.
Is it time to turn the crank?
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273241
03/31/09 11:49 PM
03/31/09 11:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It's a Slant, throw some bearings at it & go...
Re: No Oil Pressure! Cause Found With Pics [Re: 1_WILD_RT] #273242
04/01/09 12:02 AM
04/01/09 12:02 AM
I haven't opened up the pump yet. Maybe it got damaged without oil in it.
That is the copper showing on the bearing.
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273243
04/01/09 12:16 AM
04/01/09 12:16 AM
When I drained the oil I found no bearing material in it. I do have some residual oil in the pan. Haven't checked that for metal. I did find part of a distributor gear in the pickup (plastic for all you non-slanters)
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273244
04/01/09 12:49 AM
04/01/09 12:49 AM
RoadRaceDart Offline
Nice rope seal! I hate those things!
Joshua
Re: No Oil Pressure! Cause Found With Pics [Re: RoadRaceDart] #273245
04/01/09 12:57 AM
04/01/09 12:57 AM
Say what?
Really felt like cloth. It is still sitting out there on the block.
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273246
04/01/09 01:20 AM
04/01/09 01:20 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Say what?
An unraveled dog turd main seal? Perhaps. It's hard to tell from the photo.
(I vote with Randy on tossing some bearings in it and calling it good.)
Down to just a blue car now.
Re: No Oil Pressure! Cause Found With Pics [Re: 1_WILD_RT] #273247
04/01/09 10:29 AM
04/01/09 10:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And a new oil pump , it will probably be scored ..
Rope seal ??? that's a slant it's got 7 mains . someone lost a rag it appears
Re: No Oil Pressure! Cause Found With Pics [Re: JohnRR] #273248
04/01/09 10:35 AM
04/01/09 10:35 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
looks like a shop rag to me. wash it and see if its red (jk).
probably lost an oil cap at some time and they stuffed a shop rag into the oil fill hole. maybe it got caught and pulled in and eventually ended up in the pan
Re: No Oil Pressure! Cause Found With Pics [Re: JohnRR] #273249
04/01/09 10:38 AM
04/01/09 10:38 AM
My punishment for changing the oil in it. Looks like I can get rod bearings from Advanced for $24 for a set. Autozone wants $11.99 per rod. Can't get the mains to come up on Advanced. They have a crappy website.
I am going to pull one of the mains to see what it looks like. I already have the new pump. Also have one that appears to have been changed on another engine.
Time to get greasy before I go to work at 1.
Re: No Oil Pressure! Cause Found With Pics [Re: aarcuda] #273250
04/01/09 10:44 AM
04/01/09 10:44 AM
I doubt a rag could get sucked down. I am going to put some laundry detergent on it and see what it is. Sure was wrapped around the pick up tube.
I probably pull the pump and inspect it tomorrow morning. I would hate to put a new pump on it and then pump schrapnel through it.
These engines are hard to spin on a stand by yourself!!!!!
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273251
04/01/09 11:57 AM
04/01/09 11:57 AM
Only carnage was #5. Everything else is pretty. Checked 1 main and #6 #3 #4 rods.
The marks on the crank don't really catch my finger nail when I drag it across. Should I polish this journal with some Crocus cloth? And go with a new bearing?
I'll pull the pump tomorrow.
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273252
04/01/09 12:36 PM
04/01/09 12:36 PM
PA
70Duster Offline
70Duster  Offline
PA
Considering it's a slant 6, that's exactly what I would do.
Re: No Oil Pressure! Cause Found With Pics [Re: 70Duster] #273253
04/01/09 02:54 PM
04/01/09 02:54 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
try Rock Auto for bearings.
Re: No Oil Pressure! Cause Found With Pics [Re: sharpie] #273254
04/01/09 07:03 PM
04/01/09 07:03 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Make sure you look at the back of those bearing shells to see if you have any one undersized or whatever. You really should mic them
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273255
04/01/09 08:35 PM
04/01/09 08:35 PM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
Had the same problem with a 440 years ago. Guy said he was going down the freeway when it lost oil pressure. Said it's got a top end noise. Four L shaped pushrods laying on the head, but it also dropped # 5 and 7 rod caps, and buried them into the side of the block. Bent the bottoms of those 2 rods upside down, carved a quarter inch divot in the crank journals. All because he left a shop rag in it when he changed the timing set, and it sucked it into the pickup. You're lucky!
